Need to know how to setup with dishnetwork w/dvr
Need two remotes the original for Olevia and for sound and the cable company (Comcast) to change the channels. Have tried everything in the Comcast instructions still need Olevia remote and Comcast.
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
I hit the reset buttom to default how do you setup auto channel ... i have no channel its not listed in the set up menu you have to do a complete initial setup .
Jun 17, 2010 - If you have figured out how to set up your cable box or antenna to yourOlevia TV, then the hard part is done and you just need to find an ...
You'll need to use the Olevia remote and press the MENU or SETTINGS button. The choose the SETUP or MEMORIZE CHANNELS option. MEMORIZE CHANNELS may be in an ANTENNA screen.
When you memorize channels you'll need to set the option for Antenna or Cable TV then have it memorize channels.
The television will run through each channel looking for signal and memorize those it finds. Sometimes it finds a very weak signal and you'll need to manually remove some.
If cable from cable box is connected to TV, use TV remote to switch to Cable input if you have a Cable/DVR you will need to run speaker wires from Cable/DVR to a TV input
pick up the remote turn on tv....press menu...setup....tv....then channel scan....(note your tv should also be on cable broadcast not air)...hope this is helpful
Have you tried the code searching feature on the remote? I'll look through some service manuals I have, paper versions, for Olevia codes but it may take me a week or more.. Until then try the remote control search feature in the instruction panel that came with your remote and let me know..
Bill
