There is a sensor that is either knocked out of position or broken. It is not that difficult to take apart if you are a bit handy. First remove the covers and then remove the top cover.
Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
E3-40 is the copy density sensor on the drum unit. Toner is probably dropping from the drum unit onto it. You have to remove the drum to access the sensor.
J93 means = paper remained in adf . sounds like you have a problem with the reed point sensor in the adf door . little black plastic arm , right side should be dangling
