You've lost a neutral connection at: one of the terminals somewhere; inside the outlet; broken strap between the neutral pads on the standard outlet; or the tester is providing an erroneous indication.
Does it read OK on the BOTH receptacles of the first outlet? Check the terminals that provide output on the first outlet and the LINE terminals of the GFCI . Bad at the first outlet? Check the input on the first outlet. Bad? Check splices between outlet and service panel and neutral connection at neutral bus bar inside panel. OK? Check the input to the GFCI - make sure on LINE terminals and proper polarity is observed.
Double check the line and load terminal screws of the GFCI outlet. Make sure that the power coming into the GFCI is connected to the LINE terminals. Be sure to connect the HOT and NEUTRAL wires to the proper LINE terminals. Neutral conductor (white) connects to the silver colored screws and hot (black or red) connects to the gold colored LINE screws. If you are sending power out to supply additional loads that are to be GFCI protected, the rules above apply - but connect to the LOAD screws.
