1= change the batteries by new ones 2= clean the contacts cleaners with contacts cleaner 3= resolder the wires contacts batteries 4= retight the spring contacts batteries with pliers for better contacts 5= open the r.control clean the kepayds switch for dirty, oxide, and test for open, bad contacts. 6= try agan, if doesnot work go to the repair shop TV for fix it.
there is a switch at the top to use controls from dvd , then tv, wtc. switch it over or call Sony and get a new one. Make sure the sensor on the unit is not blocked.
Try using the scan or learning features on your universal remote control. Otherwise, a replacement factory remote can be ordered from BestBuy.PartSearch.com.
If you have replaced the batteries with KNOWN GOOD ones, observed the proper polarity when re-installing the batteries AND made sure the remote is in DVD "mode" (if it is a multi-remote) when trying to use it, the remote is bad. Replace the remote.
You may have missed a step in the procedure try this one. This information was found on the following website http://www.videohelp.com/dvdhacks/insignia-ns-7dpdvd/8394 It is dated as working on 01-08-08. I hope this information help you with your problem. 1.- Power on with no DVD inside the player; 2.- Press open on the DVD player; 3.- Press Menu button on DVD (or SETUP on remote control), (you see General Setup Page on the screen); 4.- Press the right key 3 times to select the Preference Page; 5.- On the remote control press 9653; 6.- Use the up and down key to select the Region, Select 0 for all regions; 7.- Press Enter. (This works with NS-7PDVD and NS-8PDVD)
I have a COBY DVD player TF-DVD7005 that hadn't been used in a while. When I charged the battery and the light went from red to green, nothing happens when I push play and the DVD doesn't spin. Could the battery be dead despite the green light and where would I get a new one?
