forgot to tell you what it does when i turn lights on. the screen turns blue and shows bcar none of the buttons respond you can not even shut it off plus it has 4 arrows in the upper left hand of the screen that point to the left and it will stay that way untill you shut the head lights off .forgot to tell you what it does when i turn lights on. the screen turns blue and shows bcar none of the buttons respond you can not even shut it off plus it has 4 arrows in the upper left hand of the screen that point to the left and it will stay that way untill you shut the head lights off .
AnonymousOct 06, 2008
I Hve a x344gt xo vision and my unit does the same thing. Everything works until i trun my head lights on an the b car signal comes on. while in the process of doing this no button is functioning. Until i turn my head lighs off then it works just fine.I Hve a x344gt xo vision and my unit does the same thing. Everything works until i trun my head lights on an the b car signal comes on. while in the process of doing this no button is functioning. Until i turn my head lighs off then it works just fine.
You can't post conmments that contain an email address.
Just had same issue with my 01 sport trac. Just purchased truck an never noticed until several days later had no tail lights. Brake light on cab worked not on bed. After days of head banging an scratching I realized when steering wheel was tilted up had lights down no lights tore into steering column was an easy easy fix. The clip tht holds harness in place on top of cold was broke an plug had slid out a bit so pushed it in good an tight zip tied it for temp fix vuala tail lights! Wanted to share so if anyone else has issue they didn't have to spend days scratching their head!
It sounds like a bad earth connection in the vehicle rear wiring loom. Check the earth wire that runs from the globe sockets in the light units and any connectors in the wiring loom near the light assemblies as well as where the earth wire is attached to the body. If necessary, remove, clean thoroughly by removing any corrosion or paint and re-attach securely.
Start by setting your auto headlight switch to off if this solves it replace your headlight switch If your car is equipped with daytime running lights there could be a short bridging them with your auto head lights look for broken or frayed wires do this also if you have installed or had someone install an aftermarket stereo or speakers/sub woofer, amplifier. Good Luck with this
