Make sure that you are using the Audio Out ports (not one of the audio in). Next go into the menu. Select the Audio setup option and see if there is a line for enabling the external speakers. (Often this corresponds to turning off the internal speakers but not always.)
I hope this helps. I'm not familiar with the specs of Techwood TV models. Some TVs only have an headphone/earphone (3.5 mm) jack as their audio out. In that case, you'll need an adapter to convert the RCA audio to the headphone jack.
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
