I removed all the water pipes and do not know how to put in place so as to work,who can help me please with some detailed pictures or find the exact order details such insurance
Hello Come over me by purchasing any of my services advertised in FixYa. I've the exploded view of your Jura Capresso Impress S7. I can't send it to you by this window as it does not allow me to send PDF files by it. If you purchase any one amoung my service, I can get a link to you provided by FixYa, by which I can send the diagram and instructions by it. OK.
on the tip of the tray there are metal contacts that tell the machine that the tray is installed. try cleaning these contacts with steel wool and on the inside of the tray with soapy water and a brush. remove excess water from tray and try
I found out where it goes, thanks to Juergen, who pointed me toward his excellent page on Jura cleaning: see figure 7d, copied here
which shows the yellow clip helping to hold on the tea pipe. I'm guessing that if you don't use the tea pipe, you will be okay. Otherwise you can just put that clip back on next time you clean the machine.
If you carry a smartphone these days and most of us do.
You need to learn to take photo's first.
Even the Las Vegas pro restoration guy on TV does that.
Sorry I don't have those photos and you'll be really lucky is someone on Fixya does. Try YouTube videos.
Machine thinks that there is no water getting to the machine. Majority of the time, this is caused by blockages of coffee in the brew group due to improper cleaning. I'm not saying that you haven't been cleaning it but that is usually the cause. How old is the machine? And has there been a cleaning tablet been put through it every day? Advise removing the brew group and check all pipes are clear, clean all loose coffee and check if you can blow through all of the pipes if you can loosen them. Clean coffee outlet/spout also. If the machines water is fed from a tank, It could also be a small bit of dirt has been pulled through. Hope this helps.
Hi
The water can come from several places, it could be coming from a leak in one of the pipe joints or the overflow system.
It is possible you have a blockage in the pipe work.
The machine will have to be taken apart to investigate.
Depends if you are happy to do that or not as it is is a little tricky and depending on cover has mains voltage present.
Please dont forget to vote this answer was helpful
I hope this Jura F90 dismantling guide may offer some clues for
your E-series machine.
Before you start remind yourself of the risks. In case of a mess up,
below I've listed a firm selling spares in Europe. In the UK it is
assumed that it you can afford the BMW of coffee machines, you can
afford to fix and service it too. However I haven't tried any of the servicing firms so they, and yours could be really, really helpful and cheap.
You will need about 4 different torx; hexagonal and possibly unique screwdriver
bits to remove all screws. A plastic pry tool (used for mobile phones)
will help where plastic lugs hold on the side and top panel.
Empty beans; water store and remove the waste tray. On the Jura F90 use
pliers to undo two oval headed screws at the back at the top. You'll be
able to remove the top panel after using a pry tool to disconnect two
lugs at the front edge.
You don't want to dismantle the coffee grinder and its hopper. Retain
the hopper's rubber seals or glue them in place before you lose them as I
did. Four screws hold the central back panel. Slide out a white key
underneath the machine (can't recall how crucial this was).
The side panels are removed by using a pry tool to release lugs all down
the edge where these panels meet the front. Work slowly to manoeuvre
the side panels off. If you simply want to clean the brewing unit
externally then just remove the panel on the water side.
Find the water inlet just where the water tank sits. A screw here allows
you to remove a plastic piece - but take a photo of how it slots in.
This gives access to the lower end of the brewing unit. If the plastic
piece is still it the way, you can ease off the water pipe from the
water inlet and put it aside.
A number of different brands are made by one firm and branded. Thus the
guts of these machines are similar. The brewing unit in the Jura F90 is
almost identical in many machines. The screws and attachment places are
different. The water inlet and valve are different. Cleaning the parts
you can now see may fix a Malfunction 8 without removing and dismantling
the brewing unit. The machine is partly operable in this state - cover
the exposed electrical connections and remind yourself of the danger
here. Thus you can switch off the power when the brewing unit's white
wheel is at the top and then at the bottom. In this way you will get
access to places causing any jam. You might just need to clear the inner
chamber and path for two plungers with two large O-rings. You can see
the water inlet nozzle with its o-ring which can perish and cause coffee
or water to go to waste. Silicone grease only where the O-rings slide.
Leave the other plastic parts ungreased. As I said you might get away
with not disassembling the brewing unit. You can however buy a
maintenance kit or a new brewing unit from the shop below.
You will want to avoid removing the nylon water pipes - unless they're
actually leaking. These pipes are held in place with a wire clip (remove
with a flat head screwdriver). Ease the nylon pipe with its brass
collar out of its socket. The pipe goes into an O-ring in the pipe's
socket - this might fall out.
Removing a brewing unit is like removing a car engine. The link at the
shop below has a pdf (Anleitung_Jura_E.pdf) There is no need to force
anything. On the Jura F90 the brewing unit is removed by undoing two
obscure screws from the coffee grinder side. I had difficulty removing
these and I wish I had taken time to find the right tool instead of
wearing down the screwhead.
On the electronic side there's an optosensor (encoder) unit held in
place with a steel clip. You might remove this to access one of the two
screws. At the bottom of the brewing unit, the water inlet valve is
fixed to the machine with a single screw. Next, on the water tank side,
you'll see two lines of screws that hold the assembly in place. The
middle screws of the screws allow you to separate the unit from the
gears. The top two holes don't have screws.
Coffee machine spare part supplies are not as common in the UK as they
are in mainland Europe. You'll find this web useful because of the
pictures: www.kaffeemaschinendoctor.de is a German web shop for machine
spares AND there's a pictorial of how to dismantle the Jura F90 as a
pdf. Google will almost translate it). Juradoctor.de also carry lots of
spares but don't seem to ship to my country.
add a capfull of the cleaning fluid to a litre of water, insert milk tube and request cappuccino clean from the cleaning button...icon of cleaning tablet surrounded by water droplets, second row second button from lefthand side...then follow screen instructions to step your way through the cleaning selections with +and - buttons.
I keep the cleaning fluid held high to allow it to continue running after the cleaning action.
Remember to run clean water through the pipes using the same method above.
Google x7 manual and you can download one of many copies online.
