Hi.
The noise coming from underneath is symptom of a problem with drain pump or drain line.
The standard procedure consists in accessing the drain filter to check if it is blocked, then testing drain pump. Most of the time the noise is caused by blockage at drain filter. In some case the pump is gone.
The control panel gets replaced only after checking drain filter, testing drain pump and also after testing the water pressure switch that determines when to start or stop the pump.
Bye.
G.
Hi
This issue usually occurs due to kinked drain pipe, clogged
drain filter or drain pump. First make sure that the drain is not clogged and
remove clogs if present. If no visible lint is present then remove the lower
front access panel to check the drain filter and drain pump for any clogs,
you'll need to clean the drain filter and drain pump completely. Hope this
helps... Please post back for any further assistance.
Daniel
