Question about Mustek PVR-A1 32 MB Digital Media Player
PVR-A1 does not work
My Mustek PVR-A1 doesn't work anymore. When I power on the device, all I get is a screen full of various assorted colored pixels. My Windows XP won't recognize the PVR-A1, and I have to remove the battery to turn it off. Is there a fix for this, or a reset option? Please advise Best regards, Robin ...
5 Suggested Answers
SOURCE:
SOURCE: mustek pvr h140
yeah, man, i did the same. cracked the glass, without damage to the screen, and then just made one myself, cutting it out from a cd-box and then glued it on :)
Posted on May 13, 2008
  • 22 Answers
SOURCE: Mustek PVR
Try Maplins, or a specialist electronic component supplier.
Posted on Jan 14, 2009
  • 4 Answers
SOURCE: HOW TO CHANGE THE MUSTEK PVR-H140 BETTERY
It is real easy to change the battery, I have done mine a few months ago
if you remove the screws from the back top and bottom (4) and remove the case
next remove the 2 small rubber strips from each side of the hard drive, then very carefully pull the connecting ribbon off the hard drive, this can be tight so gently prise apart with a screw driver,
once the hard drive is removed you will see some earthing straps just make a note of where these are located as you will need to put them back in the right place, they simply touch the hard drive,
now you shoud see the battery (very thin in a blue plastic case) you might want to remove the rubber proctective stuff just to make it a bit easier there is a simple pull/push connector
just unplug it and replace with new battery and reverse the procedure.
Dont panic if the unit fails to switch back on as mine did when i re assembled it
it was just one of those earth straps in the wrong place.
I hope this helps,
P.S I changed the battery on a unit I bought on ebay and i had nothing to loose
if you are unsure do not attemp the repair.
Posted on Jan 17, 2009
the_pete
SOURCE: AC power jack came loose from the board
This happened to me too. Just unscrew the 4 screws, lift out the hard drive and glue it back down to where it was (2 little pegs will fit into two little holes on the circuit board. You can touch the contacts with a thin tipped soldering iron if you want to but you probably don't need to.Then close it up. That worked for me!
Posted on Jan 03, 2010
MUSTEK PVR-H140 died on me
You may already know this, but tap the power button once more and it may turn on the screen.
Jan 31, 2009 | Mustek PVR-H140 Digital Media Player
In my move i lost all my acessaries and instructions etc, for my PVR-A1 Personal media player
If this helps, you can download the manual from HERE
as for the accessories, you'll just have to buy new ones..
Apr 12, 2008 | Mustek PVR-A1 32 MB Digital Media Player
Frozen in "Initalize"
you need to go to musteks website and download the following file pvr-h140_restore_files.zip from product support area
that should get your pvr working again ?.
link to support page
http://www.mustek.com/mustek/supportdrivers.php
Apr 08, 2008 | Mustek PVR-H140 Digital Media Player
Mustek pvr h140
Feb 18, 2008 | Mustek PVR-H140 Digital Media Player
Mustek pvr-h140
Are you trying to restore the files you previously had on your Mustek or just trying to get it to work as it did before the format? If you're just trying to get it to load, follow these instructions:
"Install the PVR Console software in the bundled CD and connect the device to PC. The software will help to restore system data and boot up files to the device automatically. When the copying is done, restart the device for twice."
If you're trying to restore the data you accidentally formatted, connect it to your PC and try using a program such as Free Undelete to restore the files that were previously deleted. In the program, you need to browse to the drive that your Mustek shows up as on your PC (so if the drive is X: you need to restore files on X in the program).
Jan 09, 2008 | Mustek PVR-H140 Digital Media Player
PVR-H140 doesn't work but cannot restore files
Problem is once the hard drive is corrupted you can't access usb to fix the problem. You have to remove the four screws on the back cover remove the 40gig hard drive. Find a laptop or an ide to usb adapter to reformat the drive. Must be fat32 not ntsf. Then copy all files back onto drive.
Nov 10, 2007 | Mustek PVR-H140 Digital Media Player
Mustek pve h230
My mustek seems to be able to play music files (wma/mp3) fine but i don't know how to play videos on it. I've used the converter that came on the CD with the mustek and I've also tried converting using various media converters.
Jun 18, 2007 | Mustek PVR-H230 MP3 Player
Mustek PVR-A1 32 MB Digital Media Player Logo
43 people viewed this question
Top Mustek Audio Players & Recorders Experts
John Elliott
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
