SOURCE: cannot reset to factory settings
Turn the router off.
Hold the RESET button in, for 30 seconds.
Turn the router on, and see if it has reset.
If not, then with the router still on, hold the RESET button in, for 30 seconds, and see if it has reset.
SOURCE: How can i reset Encore enRTR-104 router to default
I found these instructions for resetting the router to the defualt settings:
Use the "Backup Settings" tool to save the Broadband Router's current configuration to a file named "config.bin" on your PC. You can then use the "Restore Settings" tool to restore the saved configuration of the Broadband Router that you set before. Alternately, you can use the "Restore to Factory Defaults" tool to force the Broadband Router to perform reset and restore the original factory settings.
Restore Factory Default
To restore the factory default settings of the Broadband Router, click on the "Restore" button.
Backup Settings
Press the "Backup Settings" button to save the current setting in a filed "config.bin" or given filename.
Restore Settings
To restore the backup file to the Broadband Router, enter the path and filename on the restore settings.
You can find the manual here:
http://www.encore-usa.com/us/support/ENRTR-104
Note:
Resetting
the router to the factory defaults will delete any changes you have
made to the router, including any security settings. This should be used
as a last resort.
The first method involves simply pressing
a button located on the back of the router. The image below (courtesy
of Linksys) shows where the button is located.
Linksys WRT54G Reset Button Location
To reset your router, use the following steps:
