I cleaned my Grind and Brew as the "clean" light came on. It worked the day after that, but the next day, all it did was beep. It is less than one year old. Help!
Contact Info:
www.weber.com
Weber
Customer
Service
1890
Roselle Road, Suite 308
Schaumburg,
IL 60195
Dear Sir/Madam,
If coffee maker is used daily clean tap mechanism weekly.
To clean tap, unscrew bonnet, remove seat cup, wash in
soapy water.
Rinse all parts in hot water, dry with a soft towel and reassemble.
Be sure the tap bonnet is tightened firmly to prevent leaks.
Never insert a brush into assembled tap as it may damage
silicone seat cup.
The heating well inside the coffee maker should be cleaned thoroughly
each week, especially if the coffee maker is used daily.
Partially fill coffee maker to above tap level with white vinegar and turn on.
When red light goes off and green light goes on, unplug coffee maker and
allow to cool.
Pour out vinegar and wash interior with a non chlorinated cleanser until all
mineral deposits have been removed.
Rinse interior thoroughly with hot water, then dry with a clean towel.
If the coffee maker is used to dispense hot water, this cleaning routine
should be daily.
Click this link for more information
http://209.85.175.104/search?q=cache:4bGUC6LjVCMJ:www.birko.com.au/coffee.pdf+coffee+maker+red+light&hl=en&ct=clnk&cd=4&gl=in
thanks
good luck
I had this same problem and can be frustrating. Every part must be snugly in place. I took the removable parts out and put
them back a second time, and that did the trick. I must not have had everything
in 'just right'.
Firs unplug the unit for ten minutes and wait.
Try performing a cleanup of the machine.
If it still does not start, call Cuisinart online help at the number listed on your owner manual, or try Cuisinart at 1-800-726-0190if they cannot fix the problem online they may send you a replacement, see here.
The machine will not run if the covers for the coffee grinder, the filter basket and the machine itself) are not properly closed. It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button. Hopefully it should work.. Leyt me know..
Thank you.......
Press and hold the power button, that should reset the unit.
i found the manual if you would like it.
manual
see if this link works.
i need the serial number on the coffee maker, and i'll get it working for you.
i see the model number.
thanks
The model is DGB 300.
We already tried pressing the power button and nothing happened except a red light came on. Need another solution. Thanks.
We have the manual that came with the coffee maker, but it does not contain information about this particular problem. All of the "innards" are seated properly, but it simply won't work.
Well, we removed and replaced everything numerous times and it still didn't come on. Will try again tonight and let you know. Thanks very much.
I note that you've charged me for a solution which I've not really accepted because everything that's been suggested has already been tried.
I am well aware that the coffee maker won't work unless all the parts are seated correctly and the lid is closed, etc. (it's our second grind and brew--the first one still works (thank goodness) but some of the housing broke off and it was unsightly which is why I bought a new one). I've removed and reinserted the various parts numerous times, but the machine continues to beep and won't start. Is there a repair center located in the Schaumburg, IL area?
