Hitachi 53UDX10B 53" Rear Projection Television Logo
Posted on Jan 18, 2018
Tv book replacement
I have an hitachi 54" rear projection tv that is about 9yrs old, we lost the
booklet and need a replacemnet the model # is 53UDX1OB
we're trying to install a surround system and its asking us to turn off our
external speakers, but without the book we don't know what to do
1 Related Answer
Anonymous
  • 10594 Answers
  • Posted on Oct 01, 2008
SOURCE: external speakers
Enter your TV model number in Hitachi Manual page and find required user manual.
Hitachi projection tv quit
Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as well..................you should see an access door refer to owner book of the correct model and you can replace yourself...........it may cost around $200 and avaiolable at encompass parts .com Hitach distributor
1helpful
3answers
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
LOST REMOTE
you will need the hitachi remote that was designed for that paticular model. If you post the model number off the rear tag of the set I can post a link where you can order the replacement remote for your model.
Lost the lamp cover is there a replacemnet
short your lamp door switch.. it may cause cooling issues but it will work. put on a table take the back off look in the area that the lamp door is there will be a switch.. trip it and tape it closed.. then turn it on if the lamp turns on you've got the right one..
External speakers
Just moved, can't find booklet....need book to set up TV
To find your user's manual just in case you've lost it. You can visit http://tv.rca.com/en-us/productdownloads.html and select your tv's size and model number. In case you don't know the tv's size I'll give an example. On the back of the tv you can find the model number. Example mine is R52WH74, that means that my projection screen is a 52 inch. Write back if this isn't what you're asking for.
Jensenka
61 Hitachi Ultra Vision has double image
you will need to replace both convergence ICs they are STK392-110 you will also need six resistors (2) 2.2 ohm 1watt
(2) 1.5 ohm 1watt, (1) 3.3 ohm 1watt and (1) 1.8 ohm 1watt.
You can get replacemnet ICs and resistors at te following link with free instalation instructions. Here is the link.
http://servicemanuals.vstore.ca/
5helpful
53sbx59b Hitachi 53 inch proj tv
Call the 800 number with the new remote. Sometimes they will have additional codes. Or with the instructions with the new remote you can manually get it to work. You must follow instructions carefully. Look for this section in the instruction booklet
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
