Bosch HBN 7052 GB Stainless Steel Electric Double Oven Logo
k.s.michhiana Posted on Dec 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Its cuts electricity off - Bosch HBN 7052 GB Stainless Steel Electric Double Oven
Anonymous
Level 2:
Scholar:
  • Expert 195 Answers
  • Posted on Dec 07, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
56984
Points
313
I need more inforamation , dose the top burners work, dose any of the oven work top or bottom , Make model, serial number if you can find it
Our belling double oven lets lots of steam and heat out with the door closed, and when it gets hot it cuts out. The grill also cuts out after 10 minutes. Any ideas please
One of the prime causes of your electric oven cutting out is the thermostat, this is a safety procedure that will protect your oven from getting too hot. ... The only real way to solve this problem is to replace the thermostat to ensure your oven doesn't heat up too much.
https://www.repairaid.co.uk/oven-repairs/my-electric-oven-cuts/
I have a Kenwood CK 404 oven. Main oven not heating up. Replaced the element twice, no change. Tested the thermal cut out and found no resistance. Replaced this and it is still the same, no resistance
No resistance as in zero ohms or infinite ohms?
I would test for voltage, a shock and spark hazard if you're not familiar with electricity.
Test the voltage power to the unit, make sure it's there, to the thermostat, to the element
It may be a broken terminal connection, the thermostat.
An electrical continuity tester can also be used with the power disconnected. Start with the oven power terminals disconnected from the power source and test both terminals to the thermostat, thermal cut off, element, the whole loop needs to be verified for electrical continuity.
Oct 26, 2018 • Ovens
OVEN TRIPS OUT
Posted this several years ago. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
If that doesn't work, you will need a new sensor, as we did. But when we installed it, we used the little plastic electric plug to connect it. Two days later it started acting up again.
The instructions said to hard wire it with two small wire nuts, but since it came with a plug it made sense to use it. Finally, even though it didn't make sense, I cut out the plastic plug and hard wired it. It's been about 3 years now and we've had no further problems.
THERE IS SOMETHING WRONG WITH THAT LITTLE PLASTIC ELECTRIC PLUG. YOU MUST NOT USE IT. HARD WIRE IT.
Thermostat on hot point stove
Posted this several years ago. Don't know if it's the same oven. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
Zanucci Electrical fault. Oven cuts out and fO8
Is the model number correct. ZBF360X.
Anyway the error code fo8 normally relates to a faulty Tangential Fan.(Cooling Fan),which can be found on teh top of the cooker behind the control panel and it is there to cool said panel.
Hope this helps.
Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
Electric fan oven cuts out
you mean a convection oven??
Dec 29, 2007 • Ovens
Top Bosch Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
