Question about LG 37LG30 37 in. LCD HDTV
Broken LG LCD TV 37LG30-UD power supply?
Lately, the image and sound went off and we could hear a tickling sound inside the TV. After checking everything regarding possible power problems, nothing from the troubleshooting appendix helped solve the problem. Could it be the power supply board? Is it a good idea to buy a new one to replace it?
SOURCE:
SOURCE: Sound but no image on my LG Plasma TV
Have sound but no imagen
Posted on Sep 30, 2008
  • 3 Answers
SOURCE: LG 42pc3dv-ud
Yes you need to replace the board LG 6871QYH048B. The board has a short. Check the fuses and one of them should have no continuity
because it is open.
Replace that board and problem solved
Posted on Aug 03, 2009
  • 53 Answers
SOURCE: My LG Flat screen TV, model no. 37LG30-UD has a
It generally depends on how thick the bar is. If it is directly in the center, it is possible that your Time Control/LCD Control board needs to be replaced.
However, there is a chance that the TCON/Control board alone will not fix the issue, and you will need to replace the LCD Panel.
Depending on your initial cost, the presence of a warranty--extended or otherwise--and your willingness to get it repaired, you may want to consider another set.
Expect to pay around $200-300.00 in labor costs to put an LCD panel in, and the cost of the panel can be quite exorbitant.
Posted on Jan 24, 2010
SOURCE: power supply for lg plasma tv
i have a 60 inch tv i just order the power supply kit i want to install it myself do i have to open the whole back of the tv.
Posted on Jul 08, 2010
  • 1662 Answers
SOURCE: Cable receiving coupler broke away
The "Cable receiving coupler" looks like either a PCB or panel mount F-type coaxial connector (coax connector for short). It may be possible to remove the tuner ("cable receiving box") from the main board and replace the connector - it depends on how much damage was done to the tuner. If the circuit board is broken and components torn apart, it is probably better to replace the tuner or the entire board assembly.
I have successfully patched torn or blown foil traces around the coax connector - the key is to make sure any copper foil tape or wire used for patching matches the original shape of the printed circuit traces as closely as possible. Avoid distorting any wire coils mounted on the tuner circuit board, and observe electrostatic discharge precautions to make sure you don't blow out the glass gates inside the tuner's transistors (at a minimum keep one hand in contact with the metal side walls of the tuner while you work on it). If you have a crack in the board material, glue it back together with clear (not metal-filled) epoxy and let it cure before doing any other repairs.
If the connector is broken, contact the sales department at MCM Electronics. It's hard to tell for sure without opening the tuner, but the connector I saw in a picture of the board (costs more than the one on eBay) looks identical to the one used in many RCA tuners. (The RCA part has a flange for soldering to the tuner shield and a single pin extending down to the tuner board.) Most PCB mount coax connectors have a four-pin box-shaped shielding base around the center pin.
In short, repairing the tuner may be an option to replacement.
The best price I've found for the main board is $98.95 at Shop Jimmy (180 day warranty). I could not locate a separate tuner.
Posted on Jan 27, 2011
37lg30 lcd tv. screen appears bu images jumps and flashes.
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
Nov 04, 2016 | LG 37LG30 37 in. LCD HDTV
LG 37LG30 wont come on. Gives blue light, but screen stays black and no sound
Sounds like the problem could be in the power supply of the TV. Have a technican check for defective capacitors if you're not equipped to do the job yourself.
Apr 22, 2013 | LG 37LG30 37 in. LCD HDTV
My lg lcd tv has no picture or sound
I would have the power supply caps checked first. If the power supply checks ok, I would suspect a main board failure.
Nov 24, 2012 | LG 37LG30 37 in. LCD HDTV
After 1 hour the tv goes blank no sound or picture
The power LED light indicator still have power on?No,than the power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 25, 2010 | LG 37LG30 37 in. LCD HDTV
My LG 37" will run fine from a half to a couple hours, then i hear a "pop" and the video and audio go out. Sometimes it comes back on, sometimes i have to unplug it from the wall.
The power supply board is dying about to be dead,not giving the right voltage to the other boards on the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 11, 2010 | LG 37LG30 37 in. LCD HDTV
Lcd tv won't turn on
first check outlet power then check power cable if both ok then it may power supply board.
Apr 27, 2010 | LG 37LG30 37 in. LCD HDTV
Difficulty hearing Samsung LCD tv even with volume up to 100%
Some models are just that way. I would invest in a small surround sound system for them.
Jun 18, 2009 | LG 37LG30 37 in. LCD HDTV
LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Apr 11, 2009 | LG 37LG30 37 in. LCD HDTV
LG 37LG30 37 in. LCD HDTV Logo
143 people viewed this question
RONALD CARTER JR
