Which board is the power inverter board?
SOURCE: standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
SOURCE: constant green blinking light Mitsubishi tv WS-65513
Hello all. I have fixed my green blinking light problem on my Mit. 65513 rear project. hdtv. It is on now as I'm writing. I replaced 4 capacitors on the DM board (largest vertical standing board). I used a desolder tool from RS($15).I practiced on a discarded board first. I replaced the caps with 4 radial capacitors rated 1000uf 16v. 105 degrees c and was sure to match the polarity markings on the board(+/-)with the markings on the capacitors. That's it! I also installed a small 12v PC fan(wired to a 12v wall adapter) on the DM module casing with zip ties. You may also use 1000uf 25v 105c caps. I hope this helps-good luck!
SOURCE: blinking timer light
The blinking timer light is usually caused by bad capacitors on the DM board. The V26 DM repair kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and the Cd with instructions.
