Cameras Logo
Posted on Oct 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will the Nikon SB600 speedlight work with the Nikon D60 Camera. All the instructions mention all the other Nikon camera's but not the D60. Will the auto flsh modes work with the auto modes of the camera
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Dec 30, 2009
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443379
Points
622693
Yes. The SB-600 instructions don't mention the D60 because the SB-600 came out before the D60 existed. Bear in mind that the D60 does not have a commander mode so you can't use the SB-600 as a slave.
Basically, as far as the SB-600 instructions are concerned, just pretend that you have a D40.
Sb900 and sb600 speedlight can work together off camera?
It sure will, the flash light will trigger the other flash go to bracketing and flash and set one flash as commander and the other slave
go to nikon tutorials setting up off camera flash have fun
Sb600 keeps flashing
The the signal to the camera to shoot flash off the camera
change your settings
2helpful
Does this flash works with the D60?
Yes, but only in a limited fashion. It will not work in the camera's TTL (through the lens) mode. Follow the instructions on page 16 of the manual. If you need a manual, you can download one at
http://www.nikonusa.com/pdf/manuals/Speedlights/SB-30.pdf
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
2helpful
Nikon sb600 flash
Auto zoom only works when on the hot shoe of the camera. You also need to make sure that its in the righht mode (make sure that above the word Zoom on the display it doesn't have a "m").
Oh and of course you have to have a CLS (Creative LIghting System) compatible camera.
3helpful
Using a speedlight
the SB-22 has a voltage of around 4.5v this means that it will not fry you D60 SLR so the answer is YES you can use you old flash gun with your D60
5helpful
2answers
Nikon SB600.
The flash unit is very compact and the high voltage is at 330volts .
NIKON uses strink warap onn the ends of the tube also and the trigger lead will
pull out of the trigger coil if not careful .
If you need repair contact.
BERRIE SMITH CAMERA REPAIR
[email protected]
770-312-0719
1helpful
Professionnals tools
This flash was made in the 1990's for use on nikon film cameras. It wont work in TTL mode on current nikon models, and it has no infrared remote capability like the sb600/800 speedlights, but it can still be fired in manual mode by even the newest nikon cameras. I wouldnt throw it away, but I probably wouldnt use it that much either.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
