Hello David, welcome to FixYa.
Based on your description,I`d suggest it is the hot surface ignitor for the bake burner that is likely the problem...even if it glows, I'll explain further below.
Here's what you can try to verify if it's indeed the ignitor...if you're mechanically inclined. It'll look like this...
** FIRST unplug the range and turn off the gas to the appliance before attempting any service...safety first**
NOTE: Some ranges have an upper broiler the same as the lower (bake) ignitor ( some do some don't ) one could swap the ignitor`s ( very carefully, they are very fragile and don`t like to be handled ) this will allow you to use the bake burner, but it will leave you without the broil function...until you can purchase another.
Here's a helpful link...
http://www.repairclinic.com/PartDetail/Hot-Surface-Glow-Bar-Igniter/316489400/1197384?modelNumber=790.71402700
This will confirm or dismiss if the ignitor is at fault...99% of the time this is the case. Many people overlook the ignitor, especially if it "glows" since that gives the untrained person the impression it works...that is not the case however. (Ignitor may glow but not have sufficient amperage to open valve, or open the valve slightly, even intermittently...but not hot enough to ignite the gas).
As far as checking them you don't actually need a clamp on meter (though it is the preferred method) you can also ohm it out to test it as follows...
You should be able to find one at most brick & mortar appliance parts vendors or on-line depot's such as "repairclinic.com", "searspartsdirect.com" to name a couple.
You can ask for part number based on the model number for the bake ignitor. The number I use in most applications (it's fairly universal and replaces both long and short ignitors and works in 90% of ranges out there)... is part #12400035. (Will not work on the GE with round type ignitors though).
I would still double check with your model number with the part`s professional`s if you're more comfortable with that.
Hope that help`s. Let me know if I can assist you further or if anything is not clear and good luck.
Thank`s for visiting "fixya" for your repair needs. Please take a moment to rate the assistance you received here and a brief testimony is also appreciated.
Regards,
Macmarkus :)
SOURCE: oven not heating
i have had this problem twice. once was the heating element actually had shorted out because the little ceramic holders had broken, this necessitated getting new element. can be checked out with an ohmmeter by yourself or by taking element into appliance repair place. the other time, it was that the manual reset switch had tripped after a self-clean cycle. actually at the moment, that has happened again- design flaw perhaps in the RSD30 range?
so anyone who can tell a reasonable competent refrigeration/HVAC technician where the manual reset switch is would be appreciated.
SOURCE: i have a maytag pilotless ignition gas oven. the
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
If
problem.
Oven
heatman101
