Question about Canon MP610 Photo All-In-One Printer
Blacker Blacks. I'm using cranes lettra 300 gsm paper, it's 100% cotton. I finding even with a CMYK of 100 in each the black appears greyish black not dense black like on normal paper. I ticked use greyscale and got a great black but of course the color was all greys.  Any ideas about changing my print settings?
SOURCE:
jackboy
  • 2985 Answers
SOURCE: Poor black in colour prints
Dwonload 'Ink Saver' install it and adjust the ink flow.
Posted on Sep 24, 2007
SOURCE: MP 360 won't print
the Cartridges is Jammed on my MP360 ImageGlass all - in one Printer
Please advise me how to fix it
Thanks
Yatiha Balfour
Posted on Feb 25, 2008
SOURCE: Printer print blue instead of black
I have the same problem with my ip 5200, when printing a document in plain black.. I spoke to canon support and they suggested to save the .doc document as a txt file before printing. It works. Not too sure if this uses any colour ink to produce the black.
You can also set the printer on grayscale. However, the printer uses the colour ink to produce black.... hence printing in black & white becomes rather expensive.
If anyone has drivers to fix this problem please let me know...
Posted on Dec 13, 2008
  • 9 Answers
SOURCE: My Canon Pixma MP500 is printing only black.
Hey, Sound like something is wrong with the color cartridge. Replace the color one and try again. If that fails you might have to replace the printer as it doesn't sound like the problem is software related.
Posted on Dec 28, 2008
  • 157 Answers
SOURCE: Canon MP950 - strong black line on back side of the paper
The problem is most likely your ink catcher, it is a sponge that catches any ink when it is being cleaned. you need to remove it and clean it then put it back in. there will be instructions in your manual.
Posted on Jun 21, 2009
UNSCRAMBLE THESE LETTERS TO MAKE 3 WORDS
Did you mean 3 words which make sense together? How about 'rocket lab pilot'
If they don't have to make sense together there are many possibilites
A Bitter Pollock
A Brooklet Clipt
A Blotto Prickle
Cab Kite Trollop
Cab Tike Trollop
Cab Triplet Look
Cab Plotter Kilo
Crablike Lop Tot
Crablike Pol Tot
Crablike Plot To
Crablike Lot Top
Crablike Lot Opt
Crablike Lot Pot
Tieback Poll Tor
Tieback Poll Rot
Tieback Poll Ort
Tieback Roll Top
Tieback Roll Opt
Tieback Roll Pot
Tieback Troll Op
Tieback Toll Pro
Balletic Pork To
Blacker Pilot To
Blacker Toil Top
Blacker Toil Opt
Blacker Toil Pot
Blacker Lip Toot
Blacker Pi Lotto
Blacker Pit Tool
Blacker Pit Loot
Blacker Tip Tool
Blacker Tip Loot
Backer Pill Toot
Backer Pilot Lot
Backer Toil Plot
Backer Lip Lotto
Backer Tilt Loop
Backer Tilt Polo
Backer Tilt Pool
Bracket Pill Too
Bracket Oil Plot
Bracket Pilot Lo
Bracket Toil Lop
Bracket Toil Pol
Bracket Lip Tool
Bracket Lip Loot
Bracket Lit Loop
Bracket Lit Polo
Bracket Lit Pool
Bracket Poi Toll
Cable Kilt Troop
Placebo Ilk Tort
Placebo Ilk Trot
Placebo Kilt Tor
Placebo Kilt Rot
Placebo Kilt Ort
Back Little Poor
Back Politer Lot
Back Loiter Plot
Back Toiler Plot
Back Peril Lotto
Back Triple Tool
Back Triple Loot
Back Litter Loop
Back Litter Polo
Back Litter Pool
Back Tiptoe Roll
Back Tie Trollop
Back Rootlet Lip
Back Petrol Toil
Back Plotter Oil
Back Tooter Pill
Black Politer To
Black Polite Tor
etc etc
Dec 14, 2016 | Miscellaneous
Mfc 6490cw print is lightly black so print is not good whot is probalem
Black is very difficult for an ink jet printer. If you are using the wrong paper, it even is more difficult. Please use paper made for ink jet printers, because the paper can absorb the fluid better so the pigment is more visible. There are also different ink's you can buy, but please if it really should be black, only use the brand own ink. Not a cheaper version. Professional printers even use different blacks for photo paper and for matte paper (and ink jet paper). Just to microbe how difficult it is to get real dark black on different media.
Sep 16, 2014 | Brother 1 Black Ink Mfc6490cw Mfc-6490cw...
Color print not coming proper on 300 gsm cards
Well, I think that is over spec for your machine. Are you using a coated stock? What type, gloss, silk, matte? Is your paper cut 18 x 12?
Mar 22, 2014 | Konica Minolta Bizhub C220 Color Copier
Konica Minolta Bizhub C552 is counting Grayscale pages as color.
I changed my image/graphic into a bw bitmap image. It worked for me. I get charged one side color and the other side bw.
Aug 21, 2012 | Konica Minolta Bizhub C552 Color Printer /...
Need beaters for a black and decker SM100 mixer
I searched for replacement beaters for Blacker & Decker SM-100 type 1 (SM100) electric stand mixer for years. I found the Sunbeam Mixmaster Mixer Replacement Beaters for stand mixers, item 4955, at a large Ace hardware store. They were priced over $16.00, so you may consider buying a new stand mixer. The beaters are the correct length, snap in and grip correctly even though the ends are curved like a half ball rather than flat as the originals. The beaters turns well but I haven't tested them with the bowl because I need to find the turn table that I have in storage. The beater set was design ed to replace parts for Sunbeam stand models 2355-1, 2356-1 and 2360-2.
Jan 18, 2012 | Black & Decker Food Mixers
Shows out of paper. Says paper jam. Open door . Clear carriage. Press ok. Cannot solve problem!!! 75 years old with 1st computer!
Out of paper
Cause: There is not enough paper in the input tray.
Solution: If the HP All-in-One is out of paper or there are only a few sheets
remaining, load more paper in the input tray. If there is paper in the input tray, remove
the paper, tap the stack of paper against a flat surface, and reload the paper into the
input tray. To continue your print job, press OK on the control panel of the HP All-in-
One.
Cause: The rear door is off the HP All-in-One.
Solution: If you removed the rear door to clear a paper jam, replace it.
rear door.
Paper can also jam in the automatic document feeder. Several common actions can
cause paper to jam the automatic document feeder:
• Placing too much paper in the document feeder tray. For information on the maximum
number of sheets allowed in the automatic document feeder, see Technical
information.
• Using paper that is too thick or too thin for the HP All-in-One.
• Trying to add paper to the document feeder tray while the HP All-in-One is feeding
pages.
To clear a paper jam from the rear door
1. Press in the tab on the left side of the rear door to release the door. Remove the door
by pulling it away from the HP All-in-One.
CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
damage the print mechanism. Always access and clear paper jams through the
rear door.
Paper specifications
This section contains information about paper tray capacities, paper sizes, and print margin
specifications.
• Paper tray capacities
• Paper sizes
• Print margin specifications
Type Paper weight Input tray1 Output tray2 Document
feeder tray
Plain paper 16 to 24 lb. (60 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 35
Legal paper 20 to 24 lb. (75 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 20
Cards up to 110 lb.
index (200 gsm)
40 10 N/A
Envelopes 20 to 24 lb. (75 to
90 gsm)
15 10 N/A
Transparency film N/A 25 25 or fewer N/A
Labels N/A 20 20 N/A
4 x 6 inch photo
paper
up to 145 lb. (236
gsm)
30 10 N/A
8.5 x 11 inch photo
paper
N/A 40 20 N/A
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using.
HP recommends emptying the output tray frequently.
Paper sizes
Type Size
Paper Letter: 216 x 280 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Chapter 15
266 Technical information
Type Size
Legal: 216 x 356 mm (8.5 x 14 inches)
Envelopes U.S. #10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. #9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Premium photo paper 102 x 152 mm (4 x 6 inches)
A4: 210 x 297 mm
Cards A6: 105 x 148.5 mm
Index card: 76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Custom 102 x 152 mm up to 216 x 356 mm (4 x 6 inches up to 8.5 x 14
inches)
Top (leading edge) Bottom (trailing
edge)
Left and Right
margins
U.S. Letter
U.S. Legal
A4
Photo media
1.8 mm (0.07 inches) 2 mm (0.12 inches) 2 mm (0.12 inches)
U.S. Executive
B5
A5
Cards
1.8 mm (0.07 inches) 6 mm (0.24 inches) 2 mm (0.12 inches)
Envelopes 16.5 mm (0.65
inches)
16.5 mm (0.66
inches)
3.3 mm (0.13 inches)
Print specifications
• Resolution: 1200 x 1200 dpi black, 4800 optimized dpi color or 6 ink
• Method: drop-on-demand thermal inkjet
• Language: Lightweight Imaging Device Interface Language (LIDIL)
• Print speed varies according to the complexity of the document
(continued)
Print specifications 267
Copy specifications
• Digital image processing
• Up to 100 copies from original (varies by model)
• Digital zoom: from 25 to 400% (varies by model)
• Fit to page, pre-scan
• Copy speeds vary according to the complexity of the document
Mode Type Scan resolution
(dpi)1
Best Black up to 600 x 1200
Color up to 600 x 1200
Normal Black up to 300 x 300
Color up to 300 x 300
Fast Black up to 300 x 300
Try clearing all paper from all carriages (Top,Rear, Front, etc. then reinserting proper amounts. Even the smallest piece of paper can cause a jam. Here is a user manual in case you don't have one you can get it here: http://h10032.www1.hp.com/ctg/Manual/c00844812.pdf
This is a PDF and it is searchable and easy to navigate (Red lettering will take you to that section), so you will need Adobe Acrobat Reader (if you don't already have it you can get free here:
http://get.adobe.com/reader/
Also, once you have done all you can turn the printer off for a moment then turn it back on.
Hope this helps. Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | HP Officejet J5780 All-In-One InkJet...
Can't print in black ink.
Wipe the cartridge of cotton,don't use water.Make sure the black is not empty.
May 19, 2009 | HP PSC 2175 All-In-One InkJet Printer
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
Canon MP610 Photo All-In-One Printer Logo
35 people viewed this question
Clive
Clive
old marine
old marine
Ekse
