Lands Phones Logo
Anonymous Posted on Dec 06, 2011
6 rings before answer comes on,t0 long a wait
Callers wont wait that long before hanging up
Level 3:
  • GE Master 17,130 Answers
  • Posted on Dec 06, 2011
GE Master
Level 3:
Answers
17130
Questions
0
Helped
3635383
Points
52372
Normally the ring and the start time can be set up on the answering machine as you will need to check for the lowest ring time- 3 times which is good enough. This is possible on the most models and must be checked on this one -- the model is not specified.
How do i reset ring times numbers on vtech model cs6419-2 sn lx506402797
The CS6419 isn't an answering machine. It will ring until you pick up, an answering machine picks up, or the caller hangs up.
If you need a manual, you can get it at http://vt.vtp-media.com/media/p/document2/products/%7BE2E64041-B485-48CF-ACE8-FEB21EDF0B4D%7D/CS6419_UM_V4_20141127.pdf
How can I get more than 3 rings? I am in my 70s and disabled. I can not get to my phone to answer in 3 rings. I miss calls due to this.
  1. Pick up the home phone receiver, wait for dial tone, and dial *94. You'll hear 3 beeps followed by dial tone.
  2. Enter the number of rings you want (between 2 and 9).
  3. Listen for 2 confirmation beeps and hang up.
How to change number of rings on VTect cordless CS6114-11
The CS6114-11 isn't an answering machine. It will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on your answering machine, consult its documentation. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
CHANGE THE NUMBER OF RINGS ON THE VTECH CS6719-16
The CS6719-16 isn't an answering machine. It will ring until someone answers, some other answering machine picks up, or the caller hangs up.
If you want to change the number of rings before an answering machine picks up, please reply to this post and specify the answering machine.
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
1helpful
Please ..need to know how to get other call on call waiting.. cordless phone 5.8
Adding call waiting as a feature to your telephone can help you take calls that you are waiting for without having to stay off the phone until that important call comes in. With call waiting, you get a beep when you are on another call to let you know that another call is coming in. If you want to take the call, you follow the simple steps outlined in this article.
  1. ep 1 Order call waiting from your phone provider if you do not already have it. Cal waiting works best with caller ID features that give you the phone number and name of the person calling you. Phone numbers that have blocked numbers or use *67 to mask their caller ID will not show up on caller ID.
  2. Step 2 Take a call when your phone rings. While you are talking on the phone and hear a beep, you are receiving another phone call. Using your caller ID function, whether it's on your answering machine or on your handset for the telephone, see who is calling you. If you want to talk to them, quickly press your "talk" button to put the other call on hold or disconnect. Press "talk" again to take the incoming call.
  3. Step 3 Disregard the other phone call if you do not want to terminate the call you are on. The new call coming in may go to your answering machine. Or if you have the call back feature on your telephone, you can simply call *69. Your phone will dial the number of the person whose call you just missed.
  4. Step 4 Use call waiting as politely as you can. You might tell someone who you are talking to that you are expecting an important call and may have to terminate the call abruptly. Call waiting calls should be answered as quickly as you can. After four rings, most phone calls go right to the machine or people hang up. Promise to call your first caller back if you have to interrupt the call
Brother Multi function centre with fax, MFC 885CW we have the setting on F/T, it answers a fax after 2 rings, if a call coming in it keeps ringing, but on callers end it keeps beeping fax noises, callers...
I had the same problem using my Brother MFC 8460N fax on the same line as my regular telephone, which has an answering machine.
There was nothing wrong with my equipment. It was a set-up issue. I solved it as follows, and maybe this will be helpful to you:
Here's what I did, step by step:
1. Put your MFC and your telephone near each other, and within reach of a phone wall jack.
2. Go to the fax machine. Take the telephone line with the clip on the end of it that comes out of the fax machine. Put that into the telephone wall jack.
3. Go to the answering machine. Take its telephone line with the clip on the end of it and put that into the BACK OF THE FAX MACHINE. The port on the back of my fax machine says something like EXT TAD which means external telephone answering device.
4. Go back to the fax machine. You'll now need to play around with the menu options for the fax. My Brother MFC shows this stuff in a little screen on the front. Try and find the Fax Setup options. Next, try and find the Fax Receive options. If you do, select something like External TAD fax receive mode. Do not give up, you're almost done.
5. Next, set ring numbers on both devices, the fax machine and the answering machine. I set both devices' ring numbers to 4. I don't know if these are the optimal settings, or what happens if you set them at different ring numbers. I only know that a "4 and 4" setting works for me, and am not inclined to mess with it.
6. Final detail: the setup should be transparent to a voice caller. Someone who is sending a fax, though, might be a little confused IF, like me, they lean over to listen to their fax machine dial and screech, just to be sure it's working. Such a person may faintly hear my outgoing answering machine message before they heard my fax machine's screech kick in. They might think that they had a wrong number, cancel the fax, try again, call me with questions, etc., etc. So I changed my outgoing message to something like: 'You have reached xxx xxx xxxx. To leave a voice msg, please wait for the tone. To send a fax, please continue the transmission and it will be printed. Thank you!'
That's it. Hope this was helpful.
Best,
Wilbere
Check out my listings on http://stores.ebay.com/WILBERE
Call waiting
when the phone ring just press the answer key, when the calls end then just click yes to retrieve the lst call without disconnect the caller
Bellsouth answering machine
TS stands for "Toll Saver"
It will ring 4 times if there are no new messages waiting, it will ring 2 times if there are new messages waiting.
This has two effects:
1) If you are calling home to check your messages, you can wait 2 rings. If there are new messages to check, then it answers immediately. If you make it to 3 rings, you know there are no new messages and you can hang up before you are billed for your call. This was more useful when you would use a pay phone or hotel phone to make a long distance call home. With a pay phone you would get your "quarter" back as long as there were no messages. With cell phones,it isn't as useful.
2) If you not home (which is implied by the fact that there are new messages waiting), it answers faster, so people calling you don't have to wait as long. This could also be viewed as a security risk... it tells your callers whether you are home or not.
- Ben
Tg5632
Check your settings in your answering machine menu. 1) is it on? 2) number of rings? 3) is it set to take messages or answer only? If the machine is ringing and never answers look for a problem under items 1 and 2. If it answers, plays your greeting then hangs up on the caller, look at number 3. If all those settings are correct, power it down, repower it back up, wait a few minutes to call it.
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
