REDRVX 560 comboI am using a Digital Stream remote
Do you mean the RDR-VX560 DVD recorder/VCR combo? With the original remote for the recorder, you need to press System Menu (which is the left button on the row of large buttons above the arrow key circle). Then use the arrow keys to select Setup, press Enter and then select Clock Set. (Press Stop before attempting to access the System Menu. Then make sure that the remote is in the same mode as the recorder. The Command Mode for the recorder is set from the system menu as well. The remote can be reset by pressing and holding Enter, then press and hold 1, 2, or 3. Hold both the enter and the digit listed for 3+ seconds.)
To provide more help, I need more information about your Digital Stream remote. I'm not sure if there is a button that will match the System Menu and the Command Mode on your remote.
Remotes.com has a replacement original remote: http://www.remotes.com/store/sony/rdrvx560.html . Other sites may also have the remote for sale.
The documentation for the unit is available from Sony support: http://esupport.sony.com/US/perl/model-home.pl?mdl=RDRVX560&template_id=1®ion_id=1&tab=manuals#/manualsTab . The direct link to the manual is http://www.docs.sony.com/release/RDRVX560_EN_ES.pdf .
I hope this helps.
