Status code 3151-351f-b800-0402-c000-016b
Hello Mark Swift,
It seems as if the status code "3151-351f-b800-0402-c000-016b" is an error code resulting in a failure of receiving an update directly into the cache of the console. This also may be the cause of trying to install custom firmware. I cannot guarentee this will work, but try downloading the Xbox update from Xbox.com onto a CD and inserting it into your Xbox console to download it. If this does not work, message me back, I will keep track of this problem.
P.S. I cannot provide you with a direct link to the update because Xbox.com is not working on my laptop wirelessly. Sorry!
SOURCE: Why does my xbox say system update failed status
Your console had a problem during the update process. Carefully follow these steps: Remove any disc from the console. Leave the disc tray open. With the disc tray open, remove the power cord from the back of the console. Plug the power cord back into the console. Do not turn the console on yet. Gently push the disc tray about half-way back into the console. Push the power button on the console. Important: Do not use the controller button or the disc tray eject button to turn on the console for this step. The update should now continue. If the above steps do not work, the console might need to be repaired. This worked for me, I hope this helps you.
SOURCE: My problem is the status
is your system been modified before? have you recently change your dvd drive? states code means that your dvd drive is not accepting your new firmware. either you need a professional update your dvd drive manually or try to update your xbox manually through a usb.
thanks
www.1repairstop.com
