hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
In my bag vac, I have found that when the light shows the bag is full when its not that there is something between where it sucks into the vac to where it empties into the bag...maybe cat hair, dog hair....etc. Try removing the bag and running it, this may allow the air to flow alittle faster and force out the jam. You may also try removing the bottom of the vac, usually just a few screws, and checking to see if you can see the jam. What is happening is this jam is slowing down the air flow and the vac thinks the bag is full....also check the filter where the air leaves the bag area...also look where the bag connects, sometimes trash can hang there.....good luck
hi from uk your problem with vac may be the gauze filter on the inside of the compartment that has bag this filter there to allow air from the micro pores of the bag to expel to the exterior of vac (room) whilst preventing dust from expelling too ? normally another symptom of this is the vac cover sometimes flips up ? however if air cannot expel from compartment it will cause overheat of motor resulting in auto cut off but will reset when cooled SO check the filter gauze and renew or wash clean? hope you understand above and hope this helps ?
You will have to clean the filter and clean the main motor. I had this issue on mine and the main motor was so full of dust bunnies, that it stopped it from creating a vacuum.
when the motor stops, this is usually caused by an restriction in air flow...caused by a full bag, dirty filter or blockage. do you wait for about 30 minuites and it you can turn it on again? have you changed th dirt cup filter in the last 2 years? have you ever washed the dirt cup filter? if you have washed it, you should not have, however, once washed and dried the fibers would have expanded and will cause a restricted air flow condition.If all of this check ok, you may still have an electrical issue, and would recomend bringing that to a trusted Vac shop.
Is the overfill valve (the yellow thing) in the waste container stuck in the up/full position? Maybe it just needs to be rinses well to avoid it being stuck and shutting off the vacuum portion of the cleaner.
