I have 1 motorola l7
my problem is the bluetooth is failed to turn on
and when i put a 1gb micro sd it turn off automaticly
i try to format using pc with fat,fat32 but can't solve that.i also try too turn off first that phone and put the micro sd but that was the same problem
hope some one can help me
If bluetooth has failed to turn on,then it can be suffering from either the hardware or software problem.
you also said that mobile is also turning off, when you insert microsd card.
For that,
1. Try any other microsd card and see if the mobile works good.
If this works, then the fault is with the microsd card.
2. There are chances, that there may be virus in the microsd card that can cause this problem. Try to format it.
3. Also you can try your microsd card with other mobiles and see how it goes.
Last try is you can reset your phone and see, but have a back up of all the datas in your mobile before reset.
If none of the above works well, then you have give to the Motorola service center
or visit,
www.motorola.com/products.jsp to find the nearest service center.
Hope my info helps you,
Thanx for using fixya.
