I own a Toshiba p35-s605. For the first time today, I noticed a verticle line down the middle of the LCD monitor. What may be causing this? The line is about a hair's width in thickness. I specially see it when viewing an image with dark background. Thank you in advance.
i have a lg 42" hd tv.. same problem.. only the line appears exactly 1 hour after the set is under power. on a light background the line is "light green" ,on a dark background the line appears "red" . it will then stay on for the remainder of the power on sequence.
I have a brand new toshiba p35-S611 with the same problem, since about 2 months I had a white thick line (3") vertical on the half right side on the screen , it remains till the asll icons desktop appears , then it vanished gradually,
and now since 3 weeks another line appears on the left side but it remains more than the first one.
I connect my laptop with another pc display , it works perfectly with no line, it is obviously something wrong inside the laptop screen or system .
any body help????
I had my first vertical line about a year ago then the second about 3 inches to the right two to three months later, about 2 cm thickness. The third appeared today, a thin blue line. I connected an additional monitor which is fine so I suspect I will need to replace the original screen. I have read online comments about the cooling system problems and wondered if this had anything to do with it. I will be pulling it apart to clean the fans and hope to see a positive results on the screen but I'm not overly optimistic
The day i bought a Westinghouse 22" LCD monitor the L2220HW, I PLUG IT IN, BRAND NEW!, AND THIS LIGHT BLUE LINE KEPT APPEARING, N WITHIN A HALF HOUR IT WAS PERMINATE, NOT EVEN AN HOUR AFTER PURCHASE AND IT HAPPENED, I GOT A NEW ONE THE NEXT AND GAVE THE GEEK SQUAD A PIECE OF MY MIND! :)
I have 42'' Toshiba LCD and have a straight vertical 1 mm thick running from top to bottom at middle of screen
