I am not sure which model I have, but the picture is getting dark even I try to adjust the color or brightness. Can someone help? Do I need to clean something at the rear of the tv or something?
I FINALLY got the problem fixed!!! Gee I feel stupid. I called a great local TV repair guy and he came out and fixed it for next to nothing. The stupid part is that all he had to do was take apart the TV's front fascia and clean the mirrors and things inside....it was FILTHY!!! Then the TV was like new again. It looks so good I wanted to kiss him. He advised that you really should be cleaning that about once a year or so to prevent this problem. Also, I live in Nevada with HIGH dust so that doesn't help either.
Service man came in removed whole front screen and frame. My wife gave him some Windex, and he cleaned the mirrors? inside. It was like a miracle. Set was as bright as it was when new.
Good Day;
It sounds like your lamp is getting weak, replace lamp. Good Luck, big IRISH.
I have the same issue but with my 52' WD52525. I replaced the lamp, took quite a while to figure out how to get the stupid light to finally go out and it did. Then, since the color and picture improved some but not completely I began searching even more in the manual for what else I could do to fix the problem and make the picture what it once was. I took off the diamond screen and cleaned it, cleaned the tv itself. I also cleaned the filter and took spray air and cleaned before I put the bulb in as well. What else can I do to adjust the picture or clean it? I was unable to find a picture "brightness" that I could adjust...only colors I can adjust. Can anyone help? PLEASE! I am a woman that is relatively good at fixing things when I have to but this is really not my thing.
