I am not sure which size burton womens lexa binding to get. I already own burton mission men small from 2003 and they squeeze by boot at the sides. It is a very tight fight, and I can feel the squeeze down the sides of my feet. My Kianas are size 39 which recommends women's medium on chart but not sure I won't have same problem as the large is size 6 plus. Can you help? I am not able to go to a shop, must order on line. Many thanks
A huge proportion of footwear of all sorts are made using sizes taken from the standard Italian last. It has become a sort of tradition because Italian shoes have been world reknown for elegance - as a nation the Italians have notoriously narrow feet. People who don't have "Italian" feet usually need to buy shoes based on width fit in order to achieve comfort and in doing so will often end up buying shoes that are up to three sizes too long..
Add into this unsatisfactory situation the fact that not all manufacturers cut on the generous side, as with clothes, and the further problem when shoes are produced in metric and then converted into British or American sizes that rarely coincide, providing low cost manufacturers a further opportunity for meanness and rendering the more expensive footwear generally superior as being much closer to the size printed on the shoes or boots. Buying shoes and boots these days with preconceived notions about what size you need is a pathway to unnecessary expense and discomfort and much disappointment.
Only expensive children's shoes, exclusive brands, a very few specialist and bespoke shoes are available in a variety of width fittings for each size, leather shoes do have the benefit of "bedding in" but shoes and boots made of synthetic materials rarely do and if they do it is a slow process.
People who must buy mailorder often order two, three or more pairs at once in order to make comparisons.
If you are not in a position to do that I suggest you either have your feet measured for width and length or obtain the instructions to measure them yourself and then provide the measurements to the shoe or boot supplier or manufacturer and request they supply boots to fit the width of your obviously non-Italian feet.
SOURCE: snowboard binding
No womens large bindings are rated womens size 8 or larger, and mens 7-9. If you have burton bindings you can shorten the adjustable strap. but make sure you strap in and when you crank down the straps you should not be able to move your boots or wiggle them around.
SOURCE: I just want to ask if the Burton P1.1 2009 LARGE
Should do... Though to be safe I'd take a measurement of the board width to the shop with you and have a look at the bindings on a board of similar width..
Better still bring the board and your boots in with you and have them fit the binding and then try it for feel before you buy..
SOURCE: I have an evol snowboard (derric swinfard model)
yeah the burton custom bindings will fit they have a 3 bolt pattern but the base of the binding will turn to fit it wont have the 4 bolts like most binding but fits the same (please rate me)
