Try using a CD Lens Cleaner disc on it, but the link suggests it is a disc transport issue. That would need a Clarion Service Centre. Clarion make it branded as Macintosh.
it's the format that you are burning your cds in...read the info in your burning program to make sure you are making regular cds and not mp3 or aac or wma formats...
HI lisasmith566 IT is not a fuse problem . the problem is your the CD part of the radio must likely the cd is stock or more likely the cd drive motor is defective . FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
this is a typical problem with the factory stereo. usually there is nothing you can do for the Cd player, because most likely a cd got jammed and broke or bent some internal components. however try usig a credit card to help eject. insert it partially into the slot and pull out if the cd tries to come out. if this doesen't work then you will have to have the cd removed by tearing it apart. this usually ends up with at least one or two scratched cds and a deck in a million pieces.
Try turning off the radio and disconnecting the battery for 1 min and then reconnecting the battery. Turn on the radio and see if that reset the radio so you can get your CD out and try cleaning the CD player with a cd player cleaner. Note you have to make sure the radio is off before you disconnect the battery. Good luck and hope this helps
there are only couple options. pull radio and send to shop for repair, purchase used radio from good junk yard. or call dealer and see if there is a warranty on it. even though its 6 yrs old they may help. what they do at the dealer is an exchange
