Canon PowerShot A490 Digital Camera Logo
A
Anonymous Posted on Dec 04, 2011
When I plug the camera into the computer it says connection error
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 15, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
198
Points
My camera cannon powershot A490 always tells me that my batteries are low and cut's off even when I have just changed my batteries
Connection error
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
C195 digatal camera software tranfer problems
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
If you insist on trying the connection, what program are you using? What does the error message say?
Jan 27, 2014 • Cameras
Connect computer removable
Communication error canon a4000 install
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Code error 19 when i connect my camera
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Canon G12 does not connect to USB cable, gives error E41
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
"Communication Error"
My ixus reads "communication error" when i i plug into my pc
Consider NOT connecting your camera to your computer.
2answers
Error message "unknown error has occurred"
how to transfer picturesd from digital camera to pc just watch video
USB Connection. When connected to computer camera shuts off or displays USB error.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
