Copy following for wiring diagrams showing GFCI combo switch-outlet
http://waterheatertimer.org/How-to-wire-GFCI.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: i need instruction manual for a gfci recepticle and switch combin
power coming in from the breaker box: black wire will go to line-hot screw, and the white wire will go to the line-white screw. the switch wires coming out of the back of the gfci- 1 will go to the load-hot screw & the other black wire will wire nut to the black wire going to the light. the white wire going to the light must go to the load-white screw.
SOURCE: Leviton 8299 Combination Switch / Smart lock GFCI Outlet Leviton-
SOURCE: wiring switch and GFCI outlet tandem, so that
There should be 2 screws at the top that say LINE. This is where you connect the power wires. The 2 screws at the bottom should say LOAD. That is where you connect the second outlet.
SOURCE: i have cooper combination switch and gfci out let
Hi ,., the two screws on the one side of the combo are for the white , neutral wires, they should be interconnected with a small link. The screw at the bottom of the switch connect the black power wire, then jumper a wire between the other two screws on that side and the switch will be controlling the receptacle.
