Just going on these symptoms, you may need a new control/timer.
Inside the control /timer are electrical contacts, and when your machine gets to that part of the cycle, the contacts are not closing to allow the cycle to complete.
If you have circuit board, you will perhaps need a new one of those.
If you do not, probably a control/timer assembly.
If you type "SeasPartsDIrect" into you computer's search engine, and then type your complete model number into the blank when you are asked for it, you may look at the schematic and see whether you have a control / timer or a circuit board.
God bless your efforts.
SOURCE: door won't open Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door sensor/ lock is not working well
SOURCE: Bosch Nexxt 100 Series washer
Bosch Nexxt series 100 place clothes in machine start add detergent as always machine begins to add water for about 30 seconds then stops , sometimes stops and sounds like it is trying to drain sometimes just stops and won't unlock door even if you turn machine off. Sometimes if you switch from hot to cold washer will work just fine for a couple of days then back to just stopping.
SOURCE: my bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
SOURCE: bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
