Most times you have to unscrew the hex nut on top of the regulator (right where the gas line connects) and flip the plunger inside. It usually shows LP on one side and NAT on the other.
You need a Gas tech/plumber there urgently!!!! If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems. Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
Please tell us everything you did to convert your stovetop/oven to LP? Beside swapping the natural gas orifices for LP orifices, did you also switch the appliance regulator over to LP? When you put in the orifices did you match up the proper size ones to each different size burner according to your owner's manual? They have #'s stamped on them to identify them and some are even color coded. Were you having any similar issues with your previous stove? If so, it may be a pressure problem. I can help you solve this problem with a little more information. Douglas
the gas regulator has a round "plug" in the middle of the top and one side is marked nat an one is marked lp you can tell which fuel the regulator is setup for by inspecting this plug. the orifices for the surface burners are marked with thier sizes (.073) for instance which I believe is thousandthsof an inch. also the orifice "spuds" as they are called will often have a drop of colored paint on them to further identify them for installation in the correct burner. checkyour carburation too. if the flame is noisy and trying to shoot up of the burner you could be getting too much air. close the air off a bit till you make a pretty flame two tone blue no yellow.
make sure unit is set up for the fuel you are running (lp/nat)
make sure connections are correct and valve is 100% open no blockages anywhere if all good call for wty service you don't want to void wty on a new unit
there is a square nut on top of the regulator un screw it and underneath you will find a Cly flip that over should take care of it one side will say ( nat) the other will say( lp) you want lp up
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
