Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312 Logo
Posted on Dec 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hums seconds only does not freeze
Getting power lid light working freezer is ten or more years old
Al
Level 2:
Habit-Forming:
Scholar:
  • Expert 68 Answers
  • Posted on Dec 26, 2011
Al
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
68
Questions
0
Helped
28980
Points
144
If it hums then quits and hums and quits and just keeps doing this then either the compressor start relay is burned out or the compressor is seized. Unless you are capable of diagnosing this you should have a tech check it out. If it's just a relay they are relatively cheap, but if it's the compressor it could cost more than the freezer is worth.
1helpful
I have an igloo frf1050 10.6 cu ft chest freezer. power (red) and running (green) lights are on. compressor hums for 6 to 8 sec. then shuts off. no cooling or freezing. any help?
Compressor may be bad. Also could be the relay that plugs into side of compressor that’s bad. Inexpensive, easy to replace part if it’s the relay.
Sep 21, 2018 • Freezers
1helpful
Chest Freezer Stopped Working 14 years old
The first thing you want to ensure is that power is actually getting into the unit. i suggest that you do that by plugging a night light into the outlet and verify the presence or power. If no power, check your breakers. If power is present note that A chest freezer has only two working parts; the start relay that help the compressor start and a compressor. If you are getting clicking sound, your start relay may be out (inexpensive if you can buy it and install it yourself) or a bad compressor. if you need to call a tech for the repair, you may be able to purchase a new chest freezer that now consume HALF the power and for less than cost of repair.
3helpful
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Am I supposed to turn off the quick freeze once the deep freezer is cold?
http://www.mcappliance.com/document/MCCF5WBX.pdf
i read the entire manual and even type in the words "quick freeze" in pdf. find space and it is not in there.
heres the link read it for yourself
it only mentions green light and red light.
The “POWER” light (Green) indicates that the freezer is properly connected to the electrical power.
The “RUN” light (Red) will not illuminate when the unit is operating below freezing.
The “RUN” light will illuminate when the temperature inside the unit increases above freezing. Please
be advised that the “RUN” light may come on for a period of time when the lid is opened, when new
items are stored inside the unit or when the lid is forced open by irregular contents.
Do not call for service unless the “RUN” light has remained on for 6 hours or more. If this light stays
on continuously for a period of 6 hours, please contact our Customer Service Dept. to consult with a
representative at 888 775-0202 or visit our website to request warranty service at www.magicchefewave.
com.
1helpful
3answers
KF48 Beverage Air Freezer permently stuck on "defrost."
Unplug the fridge overnight and defrost it completely. Ensure the thermostat is properly set.
If it does not restart normal function after you plug back, then there may be a fault concerning the digital control, in that case call the number listed on the owner manual.
2answers
Stopped running
try putting on fast freeze. if it starts up this means thermostat is faulty. get back to me if you want
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
