Refrigerators Logo
Anonymous Posted on Dec 03, 2011
Where is the reset button on a ED25SM Whirlpool refrigerator
Dad, hubby and I can not find reset button
Anonymous
Level 3:
  • Master 3,640 Answers
  • Posted on Dec 03, 2011
Anonymous
Master
Level 3:
Answers
3640
Questions
6
Helped
1675830
Points
10518
Refrigerators do not have a dedicated reset button, but you can, however, reset your refrigerator in the event of a technical problem.
resetting the main unit
  • 1 Turn the refrigerator's temperature control switch to "Off."
  • 2 Unplug the power cord.
  • 3 Plug the power cord back into the wall.
  • 4 Turn the control knob to adjust it to the temperature you want. leave cord unplugged for about 30 seconds. hope this helps ! good-day !
  • 1 more comment
  • Anonymous Dec 04, 2011
    thanks...could have been helpful if it would run though...compressor now
    did you try unplugging it then plugging back in !
    working
Whirlpool GSSR26C4XXF refrigerator. The red error code icon will not disappear on the Whirlpool refrigerator model GSSR26C4XXF even after I changed the filter.
How do you reset the filter light on a Whirlpool refrigerator?
To reset the light, simply locate the water filter button and hold it down for 3 seconds. Keep your water filter in good condition by changing it regularly, using Whirlpool filters, and getting your fridge serviced by a Whirlpool technician.
https://www.manualslib.com/products/Whirlpool-Gss26c4xxf-2840449.html
https://www.youtube.com/watch?v=2bkjgihBWFI
My dad put a Whirlpool refrigerator, model ED5HEXMT00 on its side. He since became aware of the problem of oil draining. The refrigerator will not run now. Is there any way to fix this?
Hello, Gabrielle -
Since the refrigerator is new, it is probably under warranty. You or your father will need to check the warranty information which came with the refrigerator and either contact the store or online business where it was purchased or contact Whirlpool directly - whatever the printed warranty information states to do.
The refrigerator will probably need to be inspected by an authorized Whirlpool repair person.
1helpful
How to reset water filter on a Whirlpool model #WRX735SDBM00 refrigerator?
Press the OPTIONS button to enter Options mode, then press LOCK to initiate the reset, then press MEASURED FILL to confirm that you want to reset the status light. When the system is reset, the "Order" and "Replace" icons will disappear from the display screen.
How do you reset the water filter light on Model # ED5LHAXWQ00, Serial # HR02227866?
Hi, I found this handy guide:
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Rich
Refrigerator Repair Meridian
Western Appliance Repair
Is there a reset button
No,
There is no reset button on a chest freezer...
here are some tips that will help to trouble shoot the compressor problem...
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Whilpool ed25sm Cold water dispenser leaks
your water valve is bad. behind the ref. in back is a cover. unplung unit remove ref. from back wall about 2-4 ft.remove back cover and you will see a water valve. thats the piece that the hose (your incoming water supply line hooks upto) 1/2 fitting. turn water suppy off. remove screw holding valve. disconnect wires one bye one and hoses one bye one.(so you dont mix them up).if your ref has a inline water filter and has not been replaced in a while i woiuld try that first. valve is about 45-85/ depending on your model ,i do not have that.and labor roughly 75-125 to replace depending on were you live and who you use. hope this helps you.
25helpful
How to reset water filter indicator on whirlpool american fridge freezer
Resetting your "change filter" light:
  • Press the light switch (the one that the refrigerator door presses every time you close the door) 5 times within 10 seconds. OR
  • If the fridge has a filter button, press and hold it for 5-10 seconds.
1helpful
2answers
Water filter replacement
I have the same problem. I did change the filter located on the bottom front panel of the refrigerator, but the red light is still on and NO ice. I can't figure it out and I know if I call a tech, its a 300.00 bill. Frustrated.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
