On my modem the Internet light is blinking rapidly (The one between ADSL and WLAN) while it should be a solid green light. Or is that what it is supposed to do when transferring data? Also, when modem boots after powercut or just simply turning it off, the Internet light doesn't light up for long time.
SOURCE: Linksys Rouer BFR stops functioning
There's a possibility that the router is already going bad but you can try first updating the firmware of the router because sometimes this problem is related to the software of the router so you may need to update its firmware,but if still after updating and still the same a new router will be the best solution for this problem of yours..You can also call this number for technical support help and double checking if the router is bad or still can be fix 1-877-787-8749...
Don't forget to rate the solution FIXYA thank you....
First, unplug everything. This means, remove all your equipment from any power connection. Many people think that just turning a piece of equipment off and on will solve the problem. Actually as long as the equipment is plugged in, there is power to the circuits this prevents a complete reset.
Now, after maybe 30 seconds, plug in the modem and the router and then turn on your computer (I'm assuming there is at least one computer wired to the router). If the lights keep on blinking, push the reset button in the back of the router to try to reset it.
If these two things don't work, you can assume the router has been damaged, possibly by a power surge and must be replaced.
Testimonial: "Thank you. I tried the two solutions you've provided and what do you know, my router is busted -___-. Thank you though. Last question, is it possible that welding will affect it?"
