Question about Intel Motherboard
U778K I am looking for the info on dell vostro 1510 U778K motherboard schematic. I have 3 dead boards, no power when press power button green sometimes yellow LED on network jack flashes. Need info on where to get schematic diagram of this board or what IC/transistor to replace to get them back working. Thank you
    Sergeant:
  • 305 Answers
The first thing I would do is to make sure your power supply is good. I have found that sometimes they will make some of the lights come on, but they may have 12V and not 5V or whatever. I bought a small thing you plug the power supplies into, and then the lights light up to show you if the power supply is supplying what it should. Once you are sure the power supply is good, (don't assume) if they still don't work, I would visually check the boards. I have found many times the small capacitors go bad. After replacing them, the boards worked fine. Usually they will have the top cracked open or bubbled up. If you are up on electronics, as I guess you are if you know how to read a schematic, soldering in new ones is a simple matter. I also remove the CPU, clean the bottom surface off, and put a small amount of CPU grease on and reinstall the CPU. Be sure to check all the pins, as they are pretty small and easy to bend one over.
Posted on Jan 03, 2018
SOURCE:
SOURCE: Intel D845WN motherboard
www.premioinc.com/pc/manuals/mb/845si/845si.pdf page 95.
Posted on Oct 06, 2007
map9966
  • 2351 Answers
SOURCE: motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Posted on Jun 02, 2008
wayneard
  • 1901 Answers
SOURCE: I need the front panel pinout for an Emachine T2984 motherboard
Here is the pinout for several Intel MB's with 845GV Chipset.
Posted on Mar 18, 2009
  • 31 Answers
SOURCE: wiring diagram
might be this one: ftp://download.intel.com/support/motherboards/desktop/se440bx2/72163201.pdf
Posted on Apr 01, 2009
My dell vastro 1510 laptop problume is after 15 to 20 minuts laptop swichtd off outomaticaly. and then not start at any cost after day one or day 2 when u press start button it start.. after 15 to 20 min.....
-this issue will happen if you are having overheating problem in the computer, there are 3 possible problem Processor, video card or the chip set for the motherboard it self, try cleaning your air vent or filters, may be the fan inside is not working any more..
cheers
Feb 23, 2011 | Dell Vostro 1510 Motherboard System Board...
Hello. when i turn on my laptop (vostro 1510). i
I think, your laptop Ram or Bios have problem. Better u try to re_setup the windows.
Jul 10, 2010 | Dell Vostro 1510 Motherboard System Board...
Dvd will not eject from slot drive of dell vostro 1510
Restart your computer and enter set up bios. Try ejecting your dvd rom from there... it that doesn't work, get a pin and insert it in the pinhole on the dvdrom whuile pressing the eject button... that should do the trick!
May 24, 2010 | Dell Vostro 1510 Laptop
Vostro 1510 laptop. Motherboard need replacing?
The best available solution is not an happy one, but the cheapest. E-bay will usually have your part for a fraction of the price ($100 or less for the entire mobo), but then you need to take the computer apart and do the replacement work. Easy....... but terrifying!!
Apr 20, 2010 | Dell Vostro 1510 Motherboard System Board...
Not found webcam & montherboard after install windows 7
Go to Dell Website http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&catid=25&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=VOS_N_1510&hidos=WLH&hidlang=en&TabIndex=&scanSupported=True&scanConsent=False and download the required drivers for Dell Vostro 1510. Dell Vostro provides only drivers for windows XP and Windows Vista. What you can do is install the Windows Vista Drivers for your Windows 7 and hope it works.
Apr 01, 2010 | Dell Vostro 1510 Motherboard System Board...
Dell Vostro 1510 Laptop; cant get anything on the screen
Same thing happened to me.
I stumbled on this link and the solution made sense to me.
http://en.community.dell.com/dell-groups/new-to-community/f/3511/t/19323146.aspx
What I did was to nudge in the Hard drive to make sure it wasn't loose and press down slightly on the processor even though it didnt feel loose.
Worked for me. Though I'd help someone else since someone else 's post helped me.
Mar 20, 2009 | Dell Vostro 1510 Laptop
Intel Motherboard Logo
183 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
