Whenever the phone line attached to this fax rings it prints a Fax Error Report status pages for all Sent/Received "not a polling" etc...How do i stop my fax from printing all of these reports? (I had printer for 2 years, and never had problem until now).
SOURCE: Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
SOURCE: my fax log report for
No, this message only reports that your sent report which should be saved in the memory is set to Off.. which means you'll not be able to see the sent report after they are sent. This will not affect your fax. Suppose if you want to print out the Fax report, you need to set this feature On, otherwise you'll not be able to view or print the sent fax reports.
You can set this On from the Fax settings, press the Settings button on the printer, locate "Fax" and go to Fax Report and set the Fax Report to On.. use the arrow buttons on the machine to navigate through the menus and submenus.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
SOURCE: I do not know how
in the printer menu go to the fax settings --> Fax to PC settings.
that should do the trick
SOURCE: I have a HP PSC
The printer probably giving you an alignment page each time it starts up because the catridge alignment wasn't completed. Place the sheet face down on the scanner glass and press the scan start button. This will finish the process and the printer will remember it was done, and no longer print that page every time. You can download a copy of the manual here from HP if you need one for reference.
SOURCE: My deskjet F380 hewlett packard printer is
It sounds like yuor printer driver needs to be be refreshed or reloaded. go here to find the correct one - http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128296&lc=en&cc=us&dlc=en&lang=en&cc=us
