It originally came with Windows Vista. I Upgraded it to Windows 7 but the recovery partition is still there. I am now selling my computer and the person that I am selling it to does not want Windows 7. When I hit F-11 during start up it acknowledges that I am trying to to system restore but then just starts all of the way up. This happens whether I push F11 once or if I hold it until it screams at me.
Did you create a set of Recovery discs for this machine, before you wiped out Vista and installed Windows 7? There is a utility to do this and it relies on the original windows to work. When you formatted Vista, you erased the Recovery links from the windows partition, that allows the recovery to take place. The Recovery has to 'see' the original OS to confirm it is on the correct machine. It is known as a 'fingerprint' and is checked by the BIOS to make sure it is not being Pirated. If you have the key on the bottom, you may be able to download a new copy of Vista just for Compaq machines, and it will legally activate.
SOURCE: Compaq Presario CQ50-210US
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3795234&lang=en&
here u can download...
SOURCE: unable to recover my system
u need to fix error on harddisk.
u can fix those error with "chkdsk /r"
command
SOURCE: There is recovery partition on my compaq presario
Normally during the early start sequence (when the laptop displays the Compaq logo), you will need to press F9, F10 or F11 repeatedly (model varies)
Some also require you to hold the key down before you press the power button, then release it after the laptop has finished displaying the Compaq logo.
Hope that helps.
If you are still lost, post back.
Peter
SOURCE: i got a compaq cq61
didnt u make the recovery discs beforehand???? if the option for restore factory settings is shown...then go for it.....it works in my vista....u will have your notebook as it was when u bought it.....but only one problem.....you will lose everything u have on your laptop..as it is formatted...
SOURCE: how do i restore my
Your computer is infected with viruses. Solution: install and update anti-virus. You can use anti-virus free (Avira or AVG). Perform a virus scan process, with the option, if a virus is detected, the primary action "Repair" and secondary action "Quarantine".
hopefully help
