How do I brighten the LED display
I found that if I repeatedly press snooze/date/sleep off (big button) it will change the dim setting 3 levels... dunno how many times but I press it like 20-30 times and it works
Correct.....kept pressing maybe 20-25 times.....went from low before I started, then to medium with continued pressing, eventually to high....NO taking battery out necessary. BAM....FIXED
The big button
die rechte Seite tasten //the right side klicks
There is no brightness adjustment for this model, but you can remove the front lens by removing 2 screws holding it and the display will look brighter.
1. Unplug. Take out battery (round). Replug. It shall glow again. 2. Reinsert same battery for the time being. 3. But your battery requires replacement now.
thank you. and it worked
