Hello Bruce...here are the steps to follow per All Data.
Release hood latch and open hood.
Remove the headlamp assemblies.
Hoist vehicle and support with safety stands.
Remove the five push pin fasteners attaching bottom of fascia/air dam to radiator closure panel.
Remove front wheels.
Remove front wheelhouse splash shields fasteners as necessary to gain access to bolts attaching front fascia to fender.
Remove the two bolts and two nuts attaching fascia to the front fenders (Fig. 1) and (Fig. 2).
Disconnect fog lamp wire connectors, if necessary.
Lower vehicle.
Remove two bolts attaching the upper grille support to the headlamp mounting panel at each side of the grille.
Remove bumper fascia from vehicle.
INSTALLATION
Position front bumper fascia on vehicle (Fig. 1) and (Fig. 2).
Install the two bolts attaching fascia to headlamp mounting panel at each side of grille.
Install the two bolts and two nuts attaching fascia to the front fenders. The fascia should be flush to fender.
Install front wheelhouse splash shields fasteners.
Install front wheels.
Connect fog lamp wire connectors, if necessary.
Install the five push pin fasteners attaching bottom of fascia to radiator closure panel.
Lower the vehicle.
Install the headlamp assemblies.
The "push pin fasteners" are the pain you are having i believe. They push in, but to get them out you need squeeze them on the back & pull at the same time. If you happen to break a few, you can buy them in various sizes at the auto parts store. I hope this information is helpful, an owners manual will not have any info like this in it.
Sorry-- the images, are copyright owned & i can not post them here. Body shop quote is a bit high, $600 - 700 is what i was told, for labor only - If you have insurance...use it.
Did you get my question? I find the website confusing. How do I get the headlamp assemblies out? I took off the one mounting bolt that's obvious, but they still won't slide out. Please help soon - getting dark in NE Canada
Here is a video that might help you...the HL assy has 3 bolts.
http://www.youtube.com/watch?v=9-91kIXTv...
This video doesn't apply. I think they changed extensively in 09 or 10. Mine only has one mounting bolt on top, but that doesn't release it completely. Any info on headlight assy for 10 or 11 would be much appreciated. Cheers B
