Here is the perfect solution, : Guess what, that happened to my 30 minutes ago when i felt like playing my gameboy with pokemon emerald. This is an easy to solve problem, and it will work every time. This is a step by step procedure please follow the instructions one step at a time !! :::
Step one: Close the gameboy and take out Pokemon emerald
Step two: Blow into the bottom of pokemon emerald [to get dust out]
Step three: Blow into the place where you place pokemon emerald
Step four: Put it back in and test it, it the nintendo sign is all blury and weird, continue
Step five [Only do this if it still isnt working] Keep turning off the game boy and turning it back on
These problems are caused by damage done to the system or dust in the game cartridge.
If this hasnt worked,, Try it again :)
Sorry, there isn't a way to bring back a corrupted Gameboy game save. The reason the save has corrupted is because the small battery in the game had died. Replacing the battery might fix your game, but it won't bring back your save.
Nothings wrong with the Game boy.there is a small battery inside the carriage, replacing this will give the game the ability to keep saved data once again. *Note* I do not suggest doing this unless your experienced doing such thing. you can damage the board of the game if on careful.
A Game Pack is the game cartridge you insert to play a game. GameBoy Advance Games are not compatable with the Transfer Pak. The Transfer pack and Pokemon Stadium 2 only support the following: Pokemon Red, Blue, Yellow, Gold, Silver and Crystal versions. No Ruby will not work with the transfer pak as you will not be able to insert it, and the software would not pick it up.
Your battery's dead in the game, most likely. Take the screw out if you can (needle nose pliers) and see what size/number battery you need, go buy a new one, and then snip out the dead one and tape the leads to the new one with electrical (not scotch) tape. Be sure you notice which way the battery goes in before you remove the old one. Put the game back together, and you should be in business.
