Power is on but screen is black. caps lock and scroll keys are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008.
On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes.
The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved.
Battery power LED blinks
The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition.
Battery Power LED
Component Tested
Error Condition
Battery power LED off, and Caps Lock/Num Lock off
Battery or AC Adapter
AC adapter not connected or failure
Battery low charge or failure
Battery power LED blinking
Battery
Insufficient charge on the battery
When new computer is used for first time, the white LED light for the AC power connector blinks.
Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
LEDs near Caps Lock and Number Lock keys blink when starting notebook
The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up.
If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition.
Knowing the number of blinks is helpful when you contact an HP support agent for technical help.
Caps Lock/Num Lock LED
Component Tested
Error Condition
LEDs blink 1 time
CPU
CPU not functional
LEDs blink 2 times
BIOS
BIOS corruption failure
LEDs blink 3 times
Memory
Module error not functional
LEDs blink 4 times
Graphics
Graphics controller not functional
LEDs blink 5 times
System board
General system board failure
LEDs blink 6 times
BIOS
BIOS authentication failure
caps lock and number lock blink 6 times
The scroll and cap lights blink continuously what does that indicate
no model PC told, the codes vary by model and year PC was made by hP.
all this is in the manual if you read it at hp.com
all hp caps lock key blink are in fact, POST error codes, and is covered at Hp.com or in your secret PC model manual at hp.com
My laptop screen is black and caps lock and scroll key are flashing and after 2 to 3 minutes lter laptops shut down complitly.
no hp model told.
top causes are bad CMOS coin cell, bad hdd, or overheating.
Need your laptop model and the caps lock blinking code. You don't focus on it long enough for the sequence. There is a certain amount of slow blinks followed by fast blinks. This sequence, coupled with your model number, can tell us what's wrong.
Answer Source - https://coverjunction.com/fix-hp-laptop-caps-lock-blinking/
Hi allison caliri, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
no model PC told at all, vast laptops exist.
but on HP, the caps lock key falshes many codes, CALLED P.0.S.T CODES, POWER ON SELF TESTS HAVE FAILED. AND IS COVERED AT HP.COM
IN THE MANUAL THAT MATCHES YOUR UNSTATED PC MODEL.
BOTTom sticker on the PC shows model.
