SOURCE: humming inside the switch
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
SOURCE: Lutron Dimmer Not Dimming But On/Off Works
What is the dimmer rated for? Your load on the track appears to be 200 watts. A standard dimmer will burn out, you need to look on the dimmer to see what it is rated for. Did it run hot with the dimmer before you had this problem? They make dimmers for higher wattage that will do the job for you.
SOURCE: 3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
SOURCE: A fixture on a Lutron Maestro dimmer switch stopped working.
This dimmer was not made to dim a load smaller than 40VA. That halogen bulb would only have been 20VA or so.
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
I think that when your bulb burnt out, the dimmer over-volted the transformer and smoked it. That said, I think you have a fixture problem and, possibly, a switch problem, too.
SOURCE: LUTRON DIMMER
The Lutron Maestro dimmer isn't rated or designed to operate low voltage lighting as it is a 120 V-AC rated electronic dimmer. You should either install a standard low voltage ON/OFF switch on this installation or obtain a dimmer rated for use on low voltage lights.
You need special low voltage dimmer designed for use on the low voltage pucks lights you have installed. Usually the low voltage is either 12, 24, or 36 volts, depending on the manufacturer of your particular light set. Once the correct dimmer is in place, the problem with the flickering and pulsing of the lights, should cease.
If you still are having this problem and you can't find a low voltage dimmer, you can contact the maker of your low voltage light kit and they can provide you with an acceptable dimmer option for your lights.
Most Home Depot and Lowe's carry the low voltage puck light kits, and usually have accessories for these lights, including dimmer switches that will work with them.
Hope you find this Very Helpful and best regards!
PS: I found this old, unanswered question and wanted to provide a solution to close out the problem and clear the question from the site.
