Witch is hot going in & what is hot coming out
Copy following link for GM40 wiring diagrams.
Don't forget to set dip switches before applying power.
http://waterheatertimer.org/How-to-wire-GM40-timer.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
This connection is for 240 volts ONLY on the Intermatic GM40.
The first thing you need to do is make sure the Input Voltage Dip Switch (IVDS) is set correctly for 240 volts. The IVDS switch is located to the left of the terminal strip and just slightly above it. 4 is set to OFF, 3 is set to ON, 2 is set to OFF, and 1 is set to ON.
The first wire of the incoming (LINE) 240 volt cable (pick one) is connected to "L1" (the 1st terminal screw on the left). Also jumper a wire from "L1" to COM (the 5th terminal screw from the left).
The second wire of the incoming 240 volts is connected to "L2/N" (the 2nd terminal screw from the left). Also connect one of the wires (pick one) from the outgoing (LOAD) 240 volt cable to the "L2/N" terminal.
Connect the second wire of the outgoing 240 volts to the "NO" terminal (the 4th terminal screw from the left).
If you not sure which cable is which, turn OFF the circuit breaker suppying the timer, separate all the wires, turn the circuit breaker back ON. The cable that is hot is the incoming (LINE). Turn breaker back OFF and wire as above.
