The amplifier is flashing green and I do not have surround sound.
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
SOURCE: Continuous flashing green light
This link has the instructions on how to fix this problem and other similar problems. You
have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection
TVs have the red, green, and blue pots in the same order as the picture that is listed on
this link, so you may want to google search for your model's service manual. The service
manual can also help you be able to remove the cover for your particular model of TV. I was
able to find the service manual for my model, and sure enough, the order of the pots are
reversed on mine, so I would have been adjusting the wrong color. Read all of the comments
on this link too, because you can find other helpful tips and may even find someone with the
same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
You can find information on Sony blink codes here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Blurry picture/adjust convergence
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C426085
I hope this helps you!
Fare well. :)
Iconoclast
P.S. You can also clean the mirrors and dry dust while you're in there which can help with blurriness and focus. You may have to adjust all three colors to get the picture back.
SOURCE: MY SONY 006 IS FLASHING 4 GREEN BLINKING LIGHTS
U have power and sound right?The backlight video inverter board is the prob.
SOURCE: flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
