Unit has inverter light on and charging light flashing, with a intermittent click and hum. No AC power out of unit. When genset is running no charging at all, charg light full and inverter light flashing. battery volts 12.1
SOURCE: Freedom 20 stops passing good AC input after about 15 sec.
This unit does have an idle mode where it will not output without a load. What I am unsure of is if this exists only for invert mode or for both invert and pass through. Try reprogramming the remote to eliminate the idle feature and then see what happens.
SOURCE: Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
SOURCE: inverter won't charge
check if the inverter has a fuse for the charger, if it does test it if it is still ok if not change it
SOURCE: Freedom 25 Inverter charger does not fully charge batteries
The secret is in the Fishball recipe!
