Try changing your channel on the router to 11 or 1. For Linksys WRT54G routers enter the ip address of the router (default is 192.168.1.1) enter password and user name (default is admin/admin) then click wireless tab, now select a different wireless channel from the drop down box. Fix is not guaranteed to work for all consoles.
The WEP encryption has to be set on Key 1 in order for the Wii to recognize it. It's the same with the DS
I found a solution to this. I was able to pass the connection test, but I would fail during update with code 32002. The solution turned out to be to enter manually the ip address of DNS that my wireless router used. (via email, thanks jamh)
I had to change the MTU value from 0 (Default) to 1500 witch it was in the router for the Wii to finally connect and download the updates.
Hope this helps
Tom
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
From the Wii's main menu, select the Wii icon along the bottom left of the screen.
Select "Wii Settings".
Click the left arrow to get to Wii System Settings 3
Choose "Wii System Update"
Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
For any help click here
