Do any other devices or appliances spark when you plug them into the same outlet? If so, you may have a wiring problem, and you should have an electrician inspect the wiring as soon as possible.
If the iron is the only thing that sparks when you plug it into the outlet, there may be a wiring problem inside the iron, or the ground wire may not be connected. Irons are not generally expensive; you should replace the iron for safety's sake.
When you plug what in?
