Question about Canon PowerShot S2 IS Digital Camera
BLACK SCREEN I CAN NOT TAKE PICTURES
  • 20 more comments
  • twin322 Oct 06, 2008
    The described solution isn't working yet for me. When I pop open the battery lid, a beep sounds. Is that supposed to happen?
  • PaintnWiz Oct 29, 2008
    I have the same problem. Where is the shutter speed?
  • Anonymous Dec 11, 2008
    First, my screen was black and depressing shutter button would not take a picture. Taking video would result in black video. But I tried the suggested solution and the situation gradually improved. So, I think the problem (iris stuck) is identified correctly, but maybe their are also some other things 'stuck'.
    Is there some way to clean, or warm, or de-humidify, or whatever, the camera so that all parts work smoothly?
  • Anonymous Jan 26, 2009
    Thank you, worked great!
  • garypender Feb 02, 2009
    I had the same problem - hadn't used my S2 IS in months - used the technique suggested - probably `10-12 times - it finally worked!
    Thanks
    Gary P.
  • Anonymous Feb 10, 2009
    can u possibly do a set by set which button to press direction, please. I'm not too keen on what you mean by the shutter button, do you mean the take a picture button?
  • Anonymous Feb 16, 2009
    great!! thank you !! now it works fine (after 6 times)
  • Anonymous Feb 19, 2009
    black screen
  • Anonymous Feb 26, 2009
    Had the same problem was going to take in for repair, instead tried your solution... worked GREAT! Thanks. :)
  • WBCIII Feb 27, 2009
    I also have the same problem. Sending it back to Canon to see what they say. I tried the solution posted with no luck. I will let yall know as soon as Canon gets back to me. With everyone having the same problem, you would think Canon would issue a recall or repair cameras with this issue free of charge.
  • advoc21 Mar 02, 2009
    FANTASTIC! Your solution worked! Thanks a million!!
  • Anonymous Mar 04, 2009
    Same problem, solution worked perfectly!!! Took me 5 tries to unstick the iris. Thanks.
  • jpubaugh Mar 29, 2009
    Same problem - worked after 7th time!  I had to slap it too - what have you got to lose anyway?  It came back kind of dim so I repeated the process a few more times and now it's working fine.
  • guitarsoul Mar 29, 2009
    Have same problem. Camera was used everyday for 2.5 yrs until 1 yr ago when the black LCD & viewfinder started. Photo settings do appear on the screens when set to appropriate "DISP" modes, but no picture. I tried your "TV" shutter suggestion at least 15X with no success. I do notice that when the camera is turned on into "shooting" mode, the lens is noisier than I remember as it extends out. It may be dragging a little and may be part of the problem. I tried to video record - sound ok, but still no picture on playback either on the LCD screen or on my Plasma TV using the Video/Audio out jack & cable.
    Although it did not work for me, thanks for the suggestion. Any other suggestions?
    Based on cost to fix by Canon last yr, I bought a S5IS a yr ago, and I now a SX10IS.
  • Anonymous Apr 03, 2009
    I have the same problem. I will try your suggestion and post results.
    Thanks
  • ivaf100 Apr 05, 2009
    I want to thank you guys. I thought my camera was ready for the trash. I wish I had found this site before I purchased another cheaper camera. I tried your fix and my display started working on the second try. My only question, is there any way to prevent the aperture from sticking in the future. Thanks again for a great "cheap fix".
  • roseshyne200 Apr 07, 2009
    Have same problem Photo settings do appear on the screens when set to appropriate "DISP" modes, but no picture. I tried your "TV" shutter suggestion at least 15X with no success. I do notice that when the camera is turned on into "shooting" mode, the lens is noisier than I remember as it extends out. It may be dragging a little and may be part of the problem. I tried to video record - sound ok, but still no picture on playback either on the LCD screen or on my Plasma TV using the Video/Audio out jack & cable.
  • Anonymous May 12, 2009
    Had the same problem, and the described solution worked. I had to repeat the procedure several times, then everything is OK.
  • Anonymous May 17, 2009
    I have the black screen problem. Sometimes I have to turn on and off the camera for three to five times before I can take a picture. I tried out suggestion once and the camera works again! Thanks a million.
  • Wesley Elsberry
    Wesley Elsberry May 11, 2010
    Can you not take pictures, or is it that a completely black image results if you do press the shutter button?
    In the case where you get a black image, the following may be of help:
    This is a common problem in older Canon S2 IS cameras,
    especially ones that have not been regularly used. What happens is that
    the lens iris gets stuck at a small aperture. Most often you can get
    function back. Here's how:
    Turn the camera on in shooting mode.
    Turn the mode selector to shutter priority ("Tv").
    Use the four-way button on the back to set the shutter speed to 15 seconds. That's right, 15 seconds.
    Press the shutter release. Count to seven, then pop open the battery compartment.
    Wait several seconds, then close the battery compartment.
    You
    may need to repeat the above sequence several times to unstick the
    iris. If that does not accomplish it, you will likely have to send the
    camera in for repair.
    Once you have it working again, you should use the camera regularly to keep it from sticking again.
  • ken burk Jun 14, 2012
    OMG! the fix worked like a charm. I did not expect that. Thanks so much for the advice.
  • alicefillion Dec 12, 2012
    Well, I had the same problem with my Canon S3 IS. Was skeptical, but tried this solution. And, what do you know, it works!!! Thank you so much, saved me money on having it repaired. By the way, I had to do the solution about 10 times. So very happy now!
  • 4 Answers
I have the same problem with my Canon S3 IS. I was about to buy a new camera and somehow bumped into this post. I tried this solution twice and it WORKS. Thanks a lot.
Posted on May 28, 2009
  • Anonymous May 28, 2009
    Sorry. Not sure how to add comments on the first solution. Just curious. How can I delete my post.
    New Friend:
Thanks so much for great solution-ingenious!
Posted on Mar 15, 2010
    New Friend:
Thanks a lot for the suggestion. Even I had the same problem and above tip helped me to resolve the issue.
Posted on Feb 27, 2010
Hello welsberr, than for your idea from germany. Seems tham my Canon S2 IS had the same problem you described. I ould bring it in working order with your description.
Posted on Oct 05, 2008
    New Friend:
I had the same problem with my Canon S2 IS. I tried this solution and it WORKS. Thanks a lot.
Srini
Posted on Apr 18, 2010
  • aa88 Sep 28, 2010
    Thank you so much for the detailed explanation! I was amazed to see tha it worked for me!
    God bless you !!!
SOURCE:
I can take pictures with my camera, but LCD screen is black, and I can not view my pictures either
Has the camera been dropped or gotten wet? If not screen is shot and needs a new one.
Jan 30, 2014 | Sony Cyber-Shot DSC-WX10 Digital Camera
Black screen, black pictures. Shutter is not
Call Nikon support, this camera may be covered by an extended special warranty for the ccd sensor problems which were made by Sony.
Apr 19, 2010 | Nikon Coolpix S210 Digital Camera
Screen went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 27, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Set to auto shooting mode, take pictures, if still get black pictures, you need to repalce the lens unit. CCD or shutter defected.
Jul 08, 2009 | Olympus Stylus 720 SW Digital Camera
Black screen while shooting, but still taking pictures not black
Nonononooooo fotomohamed, he can review just taken pictures on the LCD. The screen is working.
Actually, it sounds like you just accidentally pressed the DISPLAY button on the back of your camera. This manually turns the screen on and off in picture taking mode to save batteries (you would then use optical viewfinder). Just press it once and it should turn back on.
Jun 19, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
I had my camera for a couple of years and the lcd screen went black, i can't take new pictures anymore.
If the screen goes black, you can still take pictures. There is no way to fix the black screen, it just blew out.
Jun 16, 2009 | Canon PowerShot A620 Digital Camera
Pictures Are All Black
I just posted a similar question I have a olympus Fe-110. I can see old pictures through the view screen, but when change the setting to take a image its all black.
Thanks
Nov 10, 2007 | Olympus FE-110 Digital Camera
Black screen
whats up with blackscreen?
Oct 08, 2007 | Fuji FinePix F460 Digital Camera
Pictures are black
If you can display pictures in playback mode but screen is black in capture mode then the CCD sensor has stopped working and needs replacing.
Sep 12, 2007 | Kodak EasyShare LS443 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
5,719 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
