Lands Phones Logo
Glenda Shibata Posted on Nov 29, 2011
How do I make a conference call using the Astra 9116lp phone?
Can you provide step by step instructions for making a conference call? I will need to connect four difference parties to the call.
Ian ruth
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Nov 06, 2013
Ian ruth
Contributor
Level 1:
New Friend:
Answers
32
Questions
6
Helped
9204
Points
38
Your provider will have to set it up for u it usually is very expensive. But google conference call and you can find a 3rd party conference company that can usually give a far better rate than your provider hope that helps
4 Related Answers
Anonymous
  • 192 Answers
  • Posted on May 12, 2009
SOURCE: Call conferencing
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Aug 13, 2009
SOURCE: How do I use the conference feature on the phone?
Press CONF get second call press CONF
There are more parties and instructions in the Users Manual.
Carl
consultel1
george peters
  • 860 Answers
  • Posted on Sep 02, 2009
SOURCE: want to know how to set up a conference call with 2 other people
yes, you guessed right
Testimonial: "So great to get such a quick answer!"
Anonymous
  • 201 Answers
  • Posted on Oct 19, 2009
SOURCE: Making a conference call
1) Call to the first party and hold the line.
2) To add new party, press CONF + 2nd party phone no, after this talk and ask the 2nd party to hold the line.
3) Press CONF again and after a beep tone, then can talk with multiple parties.
4) To leave the conference, press CONF and after beep tone, lift down the
handset.
YBC (/\)
Aastra 9116LP voicemail password
i don't know. check this link.
https://www.manualslib.com/manual/205091/Aastra-9116lp.html
if more required, please take your photo a ID and phone to
a local retailer for this phone near your location.
How can I make conference call or joint call fron vtech cordless phone
To make two-party call on your Panasonic phone and ask the person on the other line to wait for a moment.
  • Check to see if your Panasonic phone has a flash key feature. If it does, press the flash key down and wait until you hear the confirmation tone. If the Panasonic phone you're using does not have a flash key, hold down the the hook switch for half a second, then release. Dial the number of the third person in your conference call. If you're inviting someone in-house to be a part of your conference call, dial their extension number instead. If you're dialing an outside line you may need to dial 9 before dialing the number.
  • Wait for the new addition to the conference call to answer and then press the Flash key again. Wait an additional two or three seconds before pressing the number three on your telephone keypad. Start your conference call. Once you've pressed the flash key followed by the number 3, as in Step 4, your conference call is established. If you wish to add additional participants simply repeat Steps 3 and 4.
    Regards
  • 0helpful
    Cannot make conference call does my phone has that facility model #CS6229-2
    The VTech CS6229-2 - cordless phone has a two handset systems provide the convenience of operating two handsets using only one phone jack and one base station. The second handset simply needs an electrical outlet to plug into. These systems also allow you to transfer calls, conference an outside call or use the intercom feature between handsets.
    Here's an online instruction manual for your guide: http://www.manualowl.com/m/Vtech/CS6229-2/Manual/196794
    How do I use the conference call feature? Thanks so much. I need to make a conference call in an hour so I'd appreciate a response asap!
    Here's a link that has your manual which should give you specific instructions for conference calls.
    http://www.retrevo.com/support/Panasonic-KX-TG2740S-Telephones-manual/id/1074ci771/t/2/
    Hi, I was learning how to place a conference call and ended up locking two phone lines into a conference call with each other (no one at either end) and now they are both locked out and I can't release...
    PLease do below listed Steps 1. make call 2. Put first call on Hold and make 2nd call 3. Open Option button and select Conference from menu Note: you need to active conference service from your service provider and also your phone has to supported conference service.. Thanks
    Feb 26, 2010 • Cell Phones
    2helpful
    Problems with RCA 25202RE3 Corded Phone
    If you want to use the conference feature built into the phone, you need to have two telephone lines. You can't conference (3-way) with a single line.
    If you have a single phone line with 3-way calling service provided by your telephone service provider, follow their instructions. Normally the procedure is to call party 1, press the "flash" key on the phone to get a second dial tone, call party 2, then flash again to conference. But you need to have the service.
    Conference calling directions
    Downloaded manual. Thanks for your offer of help. Happy problem is solved.
    3helpful
    Conference Calls
    To establish a conference call between yourself and two other parties.
    4. After the second call is connected, press feature button then 3.
    5. Press the line or intercom button of the first held call (not required on the
    T7100/M7100 telephone).
    6. Press Release to end the conference call.
    Press feature buton then 70. The other two callers remain connected. (Some
    external lines may not support this feature. See your system
    administrator.)
    Press hold. The other two callers can still talk to each other.
    then press Release button. Press the line or intercom button of the remaining
    Conference call
    Yes u can, this feature needs to be enabled on your network provider.. [here in uk, on a normal contact t-mobile, u can make a call put it on hold make another, but not conference it in - unles you specifically ask for the feature to enabled on your line.]
    So call up up network provider and ask them if this is can be done on your line
    13helpful
    5answers
    Conference call with a Polycom SoundStation EX
    The conferencing capability to bridge 2 (or more) external stations comes from the telephone equipment/service that you have purchased. Either you are behind a PABX or Electronic KSU, which provides multiple phone service to your office, or you purchase conferencing capability from your local telephone provider (Verizon, AT&T, etc). In either case, the way to initiate a conference call would be the same as when you would have a desktop/office phone and establish a conference/bridged call to external parties. Usually this occurs by having one party on the line, flashing the disconnect button momentarily, getting a new dial tone, dialing and connecting to a second party, then flashing the disconnect button again, which signals the equipment to bridge those two calls to your station.  On the SoundStation EX there is a Flash button that provides that capability of momentarily flashing the disconnect button.  Try and see if that works. If not, then you will need to make arrangements to purchase the external equipment or service from your provider.  If you have the PABX or electronic KSU, it may also be a configuration option that you will need to have your support person for your telephone system, activate for that station connected to the SoundStation EX. Hope that helps.
    Top Aastra Telecom Lands Phones Experts
    k24674
    Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
