Hello, If your dishwasher is stuck in the drain cycle there could be two reasons for the unit doing this. The first reason is you could have something clogged in the drain line or blocking the drain pumps impellar. If the unit is not able to empty the water out of the unit the drain pump will continue to try and empty the water. The second reason would be if you had a leak condition in which if you did have a leak the drain pump would continue trying to empty the unit to prevent the unit from leaking water outside of the unit. I would first remove where the drain line connects to your drain and inspect this area first if you do not find any blockages in this area you would have to de-install the unit from under the counter and check the oppisite end of the drain line to where it attaches to the drain pump itself. If you still found no blockages you would then remove and inspect the drain pump assuring that the impellar of the drain pump is spining and that there is nothing clogging the pump as well. If you have any further questions message me back. I await your reply
Thank you
Rick
SOURCE: MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
